| ckissick |
11-07-2008 03:16 PM |
Originally Posted by Pazuzu
(Post 4288762)
Didn't realize I was going to start such an issue here. I take it back ,it's a giant stable wave that been rotating around the Earth for billions of years, and has a wavelength equal to half the circumference of the Earth. If the Moon stopped orbiting, that wave would continue around the planet at the same rate, slowly loosing amplitude until it disappeared.
I found my old text book on oceanography, and found this: "Tides are the longest waves oceanographers commonly deal with, having a period of 12 hours and 25 minutes, and a wave length of half the circumference of the earth. The crest and trough of the wave are the high tide and low tide, respectively."
Also: "The high tide does not occur directly below the moon, but is slightly ahead of it. This positioning is the result of the friction of the earth as it rotates beneath the water. The rough-bottomed ocean basins tend to drag the 'bulges' along, while the gravitational effect of the moon wants to hold the bulge beneath it. The result is a compromise position, somewhere in between, at which these two forces are at equilibrium."
If the moon were to go away, the tides would still be with us, but they would be much smaller tides caused by the gravity of the sun.
