Mothy's Avatar
Send a message via AIM to Mothy
Two High Tides
Puzzle for you all.
The earth spins on it's axis once every 24 hrs and the moon takes 28 days to rotate around the earth - hense the moon is overhead at a different time each day and the times of the tides shift a small amount each day.
The ocean tides are said to be caused by the gravitational effect of the moon acting on the earth.
If the earth spins only once per day, why are there two high tides each day?
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 11-06-2008, 12:30 PM
Bandwidth AbUser
Jim Richards's Avatar
Plenty to read about the Moon and tides...
http://www.aerospaceweb.org/question/astronomy/q0262.shtml
Jim R.
Old 11-06-2008, 12:40 PM
ckissick's Avatar
I'm a geologist. I'll take this one.
As you know, the gravitational pull between the earth and moon is what causes the tides. Over the billions of years that the earth and moon have been around, a stable "tidal wave" has developed. On the side of earth that faces the moon, you have your highest of the two daily high tides.
It seems odd, I know, but there is another, lower, high tide on the side of earth that is facing away from the moon. This is because the "tidal wave" is a normal ocean wave with a wavelength equal to one-half the earth's circumference. It has two peaks and two troughs, and it follows the moon as the moon does its orbit.
I suppose you could ask why the wavelength isn't equal to the entire circumference of the earth, with one peak and one trough. I have some ideas, but I'd have to look that one up.
In any case, it is the manifestation a true tidal wave. That's why we prefer to cause seismic waves tsunamis instead of tidal waves. Ironically, tsunami is Japanese for tidal wave, or so I hear.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 11-06-2008, 12:53 PM
Zeke's Avatar
No, I won't ask. I can see where the reciprocal tide is necessary to keep the planet somewhat in balance. I wouldn't want to live where I live if the thing wobbled. We'd have an earthquake every day.
Old 11-06-2008, 12:56 PM
Detached Member
Hugh R's Avatar
That's easy. The sun and the moon pull on the Earth as if it were a single point. The Earth shifts slightly and the water on both sides of the earth sort of bulges out a little. Hence two tides/day.
Hugh
Old 11-06-2008, 01:16 PM
abit off center
cgarr's Avatar
I am still trying to figure out if I am right on the equator and flush my toilet which way does the water go?
______________________
Craig
G2Performance
Old 11-06-2008, 01:18 PM
Bandwidth AbUser
Down, silly.
Jim R.
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
Cuz your mama jumped into the ocean twice.
Old 11-06-2008, 01:21 PM
Zeke's Avatar
Goes the same regardless of your location. Check it out on snopes.
Old 11-06-2008, 01:22 PM
Run smooth, run fast
Heel n Toe's Avatar
Yup... it goes whatever way the toilet is designed to make it go... most I've seen shoot the water in a clockwise direction.
cgarr, the question you're thinking of "is which way does the water in a sink or tub spiral when the plug is removed?"
That does go a different direction depending on whether you're above or below the equator. On the equator, I dunno.
- John
Old 11-06-2008, 01:34 PM
abit off center
cgarr's Avatar
This is cool, Now I just need to load it up and try it!!
Craig
G2Performance
Old 11-06-2008, 01:39 PM
I'm a physicist, and as much as I hate to say it...you're wrong. Sorry.
The term "tidal" and "tide" come from gravitational tidal forces. Any gravitational source puts several different stresses on any other object...it doesn't just pull it.
One of the forces is a squeezing in the transverse direction. Another is a lengthening in the radial direction. These two force together cause the ocean to form an oval (more properly, and ellipse) around the Earth (which is also being squeezed and lengthened into an ellipse, but on a MUCH smaller scale).
The math behind it is pretty complex, but the result is well understood. It's not because of an ancient stable tidal wave traveling around the planet.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 11-06-2008, 06:39 PM
I didn't look at the link in the second post, it basically says the same thing, without the big words
Mike Bradshaw
Old 11-06-2008, 06:47 PM
Bandwidth AbUser
Laplace is laughing...
Jim R.
Old 11-06-2008, 07:33 PM
ckissick's Avatar
I've read my explanation in many places. It depends on how you look at it. A physicist, maybe it was Brian Greene, even went to so far to say that there is no such thing as a gravitational force. It's just an illusion caused by the warping of the fabric of space-time.
In any case, this link gives a pretty good explanation of the two tides.
http://www.pbs.org/wgbh/nova/venice/tides.html
Charlie
1966 912 Polo Red
1950 VW Bug
Old 11-06-2008, 09:23 PM
ckissick's Avatar
Funny you should mention Laplace. I used to work on earthquake prediction research in which we used groundwater levels in deeps wells to measure earth strain. If the strain changed anomalously, the groundwater would rise or fall, and an earthquake would soon follow. That's the theory, anyway.
Because of earth tides, groundwater rises and falls twice a day as the earth compresses and contracts. To filter out these earth tide effects, we modified the data with a Laplace Transform.
Charlie
1966 912 Polo Red
1950 VW Bug
Old 11-06-2008, 09:33 PM
Registered Usurper
DARISC's Avatar
'82 SC RoW coupe
Old 11-06-2008, 09:42 PM
Slackerous Maximus
HardDrive's Avatar
I was SO waiting for a physicist VS. geologist expletive filled pissing contest. Take off the thinking caps and let the hate flow pencil necks.
2014 Cayman S, PDK
Old 11-06-2008, 09:59 PM
Registered Usurper
DARISC's Avatar
If you ain't seen a topless female physicist versus geologist mud wrasslin' match, you ain't seen nothin"
'82 SC RoW coupe
Old 11-06-2008, 10:08 PM
Bandwidth AbUser
Getting my popcorn...I'll be right back.
Jim R.
Old 11-07-2008, 03:34 AM
