Dad911: Heres a link to the regulator. http://www.radioshack.com/product/index.jsp?productId=2062600 I might be able to use a 9v regulaotr but if I see a drop like I do now, it wont work. Didnt have any 9v at radioshack anyway.
rick: So that 10.7v wont be constant? That sucks, I thought I was all set. Can you suggest how I might get a constant voltage >9v out of this 12v battery? Lube: Its a prototype for a device that will measure temperature, flow rate, and O2 percentage of a gas in a small pipeline. The information is sent wirelessly miles away to a computer that will monitor the values for any problems. |
Free minder
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Now add up how much current will be drawn by all the devices. Multiply that number by the Highest expected input votage minus the voltage you set the regulator to. This wil give you Watts dissipated in the junction of the pass transistor. Multiply that number by 19 deg C per Watt (theta junction to ambient for TO-220) and make sure that number is less than 150 deg C. Edit: and since you now have measured the current divide the amp-hour capacity of the battery by that number and see how long it will work. ![]() Edit: Edit: If you register with TI and put your buisness name along with engineer or student somewhere in the application they will send you samples of almost anything you need.
Rick 88 Cab Last edited by rick-l; 11-20-2008 at 09:40 AM.. |
Targa, Panamera Turbo
That's cool! Is this sump'n you can up with or a kit?
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Lube: I designed, built, and will install the system myself. I just graduated as a mech eng and my company gave me the task and almost unlimited funds to make prototypes for 5 locations (pictures shows one). Each component on the board is anywhere from a few hundred dollars to over a thousand. The great news is that everything works! The SCADA program I'm using is also very cool. |
edit: double post
Un-Registered User
What is the brand and model number of the oxygen sensor? I would bet that it is pulling more than 1 amp @12vdc. If you can't keep the current draw below 1 amp, that regulator wont work, even with a heat sink. I am an electrical controls engineer, and I work with these kind of things everyday. If you can give me the part number for the sensor, I can suggest an alternative way to make this work.
Don 1988 Targa |
