126coupe's Avatar
Replacing a cooling fan in my PC
The fan in my PC is very noisy. I am very mechanically inclined (I build my own Porsche race engines) but working on a computer just freaks me out.
Is it difficult to replace the fan? Where do I buy one?
Thanks in advance
Old 12-25-2008, 09:04 AM
competentone's Avatar
Replacing virtually any component in a computer is a piece of cake. If you search for the model and make of your computer, you can find the parts you need. Once you pull the fan, you'll find part numbers on it that can make your search even easier.
If you haven't opened and cleaned your computer in some time, you may find that a simple cleaning will quiet the fan considerably; it might not actually need replacement.
Old 12-25-2008, 09:20 AM
I was just doing a quick search to see if there were any good tutorials on opening/cleaning a computer and found this video. This guy actually disassembles the fan itself:
http://www.metacafe.com/watch/1695460/how_to_detail_strip_a_computer_fan/
Here are some good basic instructions for cleaning the case:
Case Cleaning:
This is where the dust goes at night to cuddle up with your processor. Dust is not your friend, it is not something to be laughed at, and it deserves respect. This is war ladies and gentlemen! Load up with some compressed air because you?re heading off to the frontlines! Actually, cleaning a computer case isn't that difficult. In fact, the entire process won't take more than about 20 or 25 minutes if the dust is really bad.
1. Turn off your computer.
2. Remove the side cover of the computer case, exposing the motherboard and other hardware components.
3. Inspect all cables and connections. Be sure to look for cables that are frayed, loose, pinched, snug or otherwise damaged. If you come across any cables that are damaged in any way or form you should immediately replace them. If a cable is frayed do not attempt to patch it up with electrical tape, this is very dangerous fix. We also advise that you replace snug cables with longer ones before it accidentally snaps.
4. Now its time to get out the compressed air. Shoot the canned air at everything in your computer. Pay special attention to the heatsink and fan on top of your processor. This area collects a lot of dust. Some other areas to focus on are add-on cards (audio/video/modem), case fans, hard disks, power supply and removable media drives (cd-rom). A vacuum may help suck out the dust while you knock it loose with the compressed air. Caution: Follow the directions on the back of compressed air! Do not spray hardware at close range! If you choose to use a vacuum, do not attempt to vacuum anything in your computer!!!
5. If you notice dust in the PCI and AGP slots of your motherboard it may be wise to remove each add-on card and shoot some compressed air into the slots to break away the dust.
6. If your case has an air filter remove it and run it through warm water to remove the dust. To dry it simply use a cloth (lint-free if possible) and gently dab away the excess water. Place the filter back into the case.
7. Replace the side cover of the computer, but check first that there aren?t any cables that are lying next to any fans. Fasten the cover and restore the power.
From here: http://www.computerclub-brac.nl/schoon.htm
Old 12-25-2008, 09:27 AM
slodave's Avatar
Which fan? Power supply fan is the hardest to replace,as you need to solder, but is straight forward.
Old 12-25-2008, 01:16 PM
Slackerous Maximus
HardDrive's Avatar
Why would you bother? I'm just sayin'......
Case fans, CPU fans, mainboard fans.......all very easy. Radio Shack should have them. Fry's will have tons.
2014 Cayman S, PDK
Old 12-25-2008, 10:03 PM
nightheart's Avatar
It's pretty easy. open the case, turn on the power and see which fan is making the noise. Turn off computer. If the fan is full of dust and crap, get some compressed air and blow it out. If that doesn't work, there should only be 2-4 screws holding it in place, and 1-2 wires. Unscrew the screws, and unhook the wires. Remember where the wires were connected, to re-install. Take old fan to any place that sells or repairs PC's, and get a replacement. Pay attention to the direction of airflow when removing the fan. If its on the case it'll either be sucking air in or blowing it out, and put the new fan on with the direction of air flow being the same. If it's in the power supply, its a little more difficult than that.
This was probably posted from my phone, so please excuse any typos.
Old 12-25-2008, 10:22 PM
slodave's Avatar
It's less expensive to replace the fan, than to replace the power supply. It's a 15 minute job.
Old 12-25-2008, 10:30 PM
