-   -   need speed shop for LQ9 engine (http://forums.pelicanparts.com/off-topic-discussions/451400-need-speed-shop-lq9-engine.html)
stevepaa 01-15-2009 06:50 AM
Anyone know of a speed shop in SF Bay Area that could tune an LQ9 engine with drive by wire. We put this in my son's 69 Chevelle and it has a rough idle at stop, and seems this is not too unusual. So looking for someone to reprogram it to raise the idle. thankshttp://forums.pelicanparts.com/uploa...1232031008.jpg
legion 01-15-2009 06:52 AM
I'd think there'd still be an idle adjustment screw on the throttle body.
stevepaa 01-15-2009 06:55 AM
not on a drive by wire.
and good morning, Chris, still cold there?
legion 01-15-2009 07:32 AM
Yep. Very cold.
I think I'm going to go through two cycles of warming the truck before I drive home. (It only runs for 10 minutes if I start it with the remote start.)
So, is it programmed to keep the throttle open a little to control the idle then?
Have a second servo to open/close a separate idle passage seems like and inneficient design to me.
legion 01-15-2009 07:33 AM
Wait, that looks like the engine in my truck...
stevepaa 01-15-2009 05:30 PM
likely is. does yours have rough idle at stop signs?
legion 01-15-2009 05:48 PM
I looked it up. I have the 5.3. That is the 6.0. Same basic design though.
Rough idle? Not that I'd notice. This is the quietest vehicle I have ever owner. I can't hear the engine idling from inside the truck.
stevepaa 01-15-2009 07:05 PM
this makes a real throaty sound, you can tell where he is 1/4 mile away.
legion 01-15-2009 07:42 PM
It has a lot to do with the exhaust too. I swear my truck has a muffler the size of a 30-gallon garbage can under the bed.
911boost 01-15-2009 07:54 PM
I want pictures, that is sweet. I bet that car is bad a$$.
Bill
kaisen 01-15-2009 08:11 PM
www.ls1tech.com
stevepaa 01-17-2009 04:04 PM
yeah, he is a member there
we found one vacuum leak, but has not cleared up everything
http://forums.pelicanparts.com/uploa...1232237072.jpg
http://forums.pelicanparts.com/uploa...1232237086.jpg
scottmandue 01-17-2009 04:22 PM
Did that come out of a corvette? The guy (or gal) up the street has one and it sounds a little rough. I just presumed the owner had modded to sound that way.
Have you checked all the plugs and wires?
Oh and BTW that is one of my favorite body styles...I HATE YOU! :p
SmileWavy
stevepaa 01-17-2009 04:34 PM
came out of a Denali
he is out now seeing if the computer will relearn after stopping the vacuum leak
Zeke 01-17-2009 05:44 PM
The vacuum leak must have been on a hose to a sensor, right?
stevepaa 01-19-2009 10:55 AM
No, it was on the side of the air intake body up top where there was a plug just past the MAF. The rubber seal was twisted and we used an o-ring and it sealed it.
RANDY P 01-19-2009 12:12 PM
Too bad you can't read this Steve since I'm on your (restricted) list, but you need to have the ECM programed with a program like HPTuners.
There's no adjustment screw. Such a shame, looks like a nice car.
rjp
stevepaa 01-19-2009 12:27 PM
hi randy, you came off starting the new year
yeah, we are looking for a tuner. the tuner at the local speed shop left to go work at another place 150 miles away.
