Questions about the water landing
Things I haven't heard addressed:
1) How did the pilot know it was a double bird strike? Do he get some kind of indicator of such? How does he know he hasn't had some other engine failure or fuel problem? 2) How did he control the plane without power? Do these jets still have that drop down air powered compressor/pump for hydraulics? 3) How high up was he? Do those things glide very well? 4) Did they know the plane would float?
David 1972 911T/S MFI Survivor |
THE IRONMAN
2-There are back up...electric driven hyd. pump or ram air turbine. 3-These thing (Airbus) glide very well...but he was loaded, no altitude to play with and no speed buffer....Remember Air Transat A-330 in the Azores in 2001....! 4-If you ditch at a great speed, the engines act like scoops and torn the wing away...The ditching speed was slow enough to prevent this and he probably put her in the water on stall with the nose up.... In fact....A really...really good pilot.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Run smooth, run fast
I think the news said he was at 3200 feet when the bird/s went into the engine/s.
- John "We had a band powerful enough to turn goat piss into gasoline." |
I wonder what the glide slope is on a commercial jet.
The glide ratio on a 747 is 17 to 1, a 767 is 12 to 1. Jets actually glide pretty well but there is a huge drag increase on a swept wing as you decrease speed below optimum and increase angle of attack.
-Jess |
Beside having a pilot license the pilot also has a glider license.
How does that compare the little private planes we see at the local airports?
THE IRONMAN
I doubt than the 747 got a 17 to 1 glide ratio...A Cessna 150 get about 12 to 1.
Tree-Hugging Member
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
THE IRONMAN
Simply incredible....And the ratio of the Concorde is 7 to 1....And the Space Shuttle at 4.5 to 1....!!!
Tree-Hugging Member
Yeah - seems odd, but the 172 has all kinds of junk sticking out: struts, gear, and prop (which is a big speed brake when it's not doing its job). A jet with low wing-loading can have a very good lift/drag ratio.
There was a case a couple of years ago.... the ground crew did not load an adequate fuel load on board a commercial aircraft making a trans-Atlantic crossing... and the aircraft ran out of fuel hundreds of mile out.. glided like >>> forever.;... made a landing at Ladjes , Azores...
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Free minder
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
1.I've had many bird strikes over the years- you generally know when you've hit birds-esp. if it's VFR and you fly through a flock of them.
2.Never flown a 'bus, but yes, you do need hydraulic power for flight controls. Not much time to deploy a RAT (if the A320 even has one) which requires a fairly high airspeed to be effective. My GUESS is that they had some degraded power from one or both of the engines. No engines running=no hydraulics/electrics. I can't imagine they had the APU running (day, VFR, high cost of fuel...) 3.Don't know about glide ratio on the A320-don't matter-ya get what ya get. 4. Most planes will float for a bit depending on the condition after impact. Evidently the A/C had a "ditch switch" that closes ports on the ship. You hope the plane will float. BUT....EVERYTHING (including my reply) is pure conjecture (BS) untill the NTSB has released their report. Hats off to the captian and crew for their jobs- any time you ditch and everybody lives is quite remarkable and indeed praiseworthy.
Ray '88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia |
THE IRONMAN
In 1983, an Air Canada 767 glided in all the way from cruise altitude to touchdown on a closed runway in Winnipeg. Here's a link to the story: http://www.wadenelson.com/gimli.html
