I'm in Tioga County, where are the rural highlands? Certainly there are building codes, I believe Pennsylvania has adopted the International Building Codes, but square footage determines the permits by townships (at least here it did). Under a certain number of sq. ft. no permit required, then from there to a certain sq. ft. doesn't need to meet code, above that structures must meet code.
23 acres isn't really much land. There are pretty remote areas of PA, but the idea that nobody will ever know is unlikely, maybe they don't know the codes enforcement officer, but maybe they do. That township's inspector might have hunted right there for decades and doesn't like the idea of an "upfrom" buying and hunting there. Everyone knows all the problem hunters are drunks from Pittsburgh or Philly, so if you get caught cheating, expect it to be expensive. My advice (and it is worth exactly what it is costing you) is to find out what the sq. ft. limit for a no code structure is and build to that. If you need storage, build a shed small enough that it doesn't need a permit. I don't know about septic, possibly an outhouse, I have very little understanding of sewage permits other than perking for an inground system is pretty rare. And I'd haul in a generator for electric. |
Will you send him a hacksaw in a cake when they throw his ass in the slammer? |
From a conversation I had this morning, the septic is a real issue. I was told (certainly not an unimpeachable or 100% up to date source, but one I trust) that in PA even a composting toilet must have an approved septic system. If you just want a cabin for sleeping and eating and don't plan on installing plumbing, I think I'd couch my permit request in terms of a supply shed for hunting/camping equipment, and would not allude to plans for even part-time habitation. If you want to do it all on the up-and-up, probably setting up a site for a trailer would be easiest, but to build I could see needing a septic permit from the sewage enforcement officer, and there is no guarantee that the land would perk for any system regardless of cost.
That sounded like a pay off. I wonder if Blageo could use that as a defense? |
The problem is when someone else stumbles across it while out hiking, or you lend it to a friend for a weekend, or you have someone over with you while you're using it, or you sell the land and someone else goes into it, then the thing falls down and kills someone. Check with the local agency before you do anything else to find out what the requirements are. If you just say "screw it" and build without permits or try to "get cute" by abusing loopholes, they eventually WILL catch up with you and it'll be far more difficult, expensive and time-consuming to set things right. There are a lot of homes sitting on the market right now (mostly bank-owned) that are having to be demolished due to "non-permitted work". It's too expensive for the banks (or any prospective buyers) to bring the paperwork up to snuff with the cities, so the banks are just opting to demo the buildings and sell the raw land. Building departments and inspectors are (more often than not) reasonable people who will work with you - until you try to ***** them over. Then they can, will and SHOULD get very nasty, very quickly. Either call the city or go down there yourself or for chrissakes stop being so cheap and hire a professional to do the initial investigation for you. Why is this even a subject of discussion? Do you guys try to cheap out on your own brain surgery too by advertising for guys on Craigslist or what? |
But if all he wants to do is put up a pole building to keep himself and his belongings dry and secure, why should an inspector fail the construction because he doesn't have R-38 insulation in the ceiling, or have the DEP run an endangered species impact study for a shed? As for calling the city, or going down himself, well, there is no "city". None, and likely no zoning. In all probability the sewage enforcement officer will be in one township, the permit officer in another, the building inspector in third, and you will need to submit the survey and permits to the county. If he is building with full utilities, the permit process will be quite cumbersome, and here I must advise quite firmly: Get the survey done by a surveyor familiar with the local gov't. entities and procedures. |
That's my take too. They obviously want their pound of flesh and some occasionally want their butts kissed a little, but if you go in and stroke their egos a bit and not with a cocky attitude (essentially let them feel like they're 'the guy') you get results and assistance. If you go in with a "my poop don't stink" attitude or like "I've done a dozen of these and I resent having to jump through your agency's B.S. hoops", they'll make life miserable for you. I've seen it happen enough times.
For the most part, most of the guys (and gals) in B&S departments are just there trying to do a job, not to impede your progress or be unreasonable. If you give them a REASON to be unreasonable and make life difficult for you, they will. Same goes for Fire Dept's, Planning Dept's (although they actually tend to be the worst, IMHO), etc. How hard is it really to pull up a web page, make a phone call or go down and talk to a guy behind the counter for 20 minutes? Really? |
| All times are GMT -8. The time now is 10:25 PM. |
