-   -   Need Help with my BBQ (http://forums.pelicanparts.com/off-topic-discussions/455368-need-help-my-bbq.html)
vash 02-06-2009 10:02 AM
BBQs galore is expensive to begin with.
futuresoptions 02-06-2009 11:11 AM
Am I missing something?, Just blast the rest of the porcelain off, put bacon grease over all of it and put them back in the cooker for about half an hour on high heat.... just hit them with a wire brush prior to each use... Or use aluminum foil over them each use... and last but not least.... take them out, put in some support rods (Rebar if thats all you have) and buy a single piece of stainless steel expanded metal to put over the support rods as your new grill surface... Back in the day our grill was cinder blocks and a shelf out of an old fridge.....;)
austin552 02-06-2009 02:15 PM
Originally Posted by tabs (Post 4467796)
FK em all with their snobbery of low and slow over wood. If ya like your gas grill then by all means use it.
No Pelican badge for your grill.
TerryH 02-14-2009 08:45 PM
Originally Posted by PorscheGAL (Post 4466159)
Alton Brown on Food network suggests you put the grates in the oven on self clean. Try it. It can't hurt.
I did just that today and must say it works great or is it grate? I've always wire brushed the tops, but the underside needed scraping with a putty knife. Two SS grates that just fit in our 24" wall oven. Three hours later they came out with just white ash. Wire brushed them and then washed with SOS pad to get a little shine back. While I was at it, I scraped out the whole bbq and even changed the drip pan.
Almost hated to get them dirty again. Thanks for the tip!
http://forums.pelicanparts.com/uploa...1234673040.jpg
