sudo apt-get purge 930
equality72521's Avatar
Remote desktop connection to Mac??
Can someone step me through setting this up? I need to setup a vnc/remote desktop server on my Mac at home which is running the latest version of Leopard. I need to be able to connect and control the Mac desktop from my Windows XP machine at work. Can someone give me step by step instructions on how to do this? I've Googled it and tried everything but it still doesn't work. I'm using a Linksys WRT300N router. I have port forwarding setup on the router to point to the Mac (port 5900). When I try to connect I use the IP assigned by my ISP, not internal IP. It works inside my network but not from outside. Any ideas?
--clutch-monkey
Old 02-17-2009, 08:54 AM
The Unsettler
stomachmonkey's Avatar
Leopard has VNC built in.
Go to System Preferences/Sharing
Enable Remote Management
Click Computer settings, mid/upper right of pane
Enable VNC Viewers can Control Screen with password
You may need to open/forward additional ports on your firewall, 5900 is standard but you may need to add 5901,5902, 5903. I'd look at his if you continue to have problems, IE should not be necessary under normal circumstances.
The last digit being the "display" that gets connected to.
Setup does sound correct, your client on the XP machine should be pointed to your external IP and the port forwarding handles the rest.
Which make and model of router is it?
Since it works internally I'd say you've got both machines correct, look more at the firewall.
"I want my two dollars"
"Brandon Won"
Old 02-17-2009, 09:11 AM
I thought I tried that but not sure now, I've tried so much. The router is a Linksys WRT300N. I've also got port 5800 and one other that was suggested on another forum but can't remember what it is now.
--clutch-monkey
Old 02-17-2009, 09:19 AM
I'll try it again tonight with your suggestions.
--clutch-monkey
Old 02-17-2009, 09:20 AM
Family Values
KaptKaos's Avatar
Go to LogMeIn.com .
They have a free service that I believe supports Mac. I know their rescue product does.
Good luck!
- Joe
Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves. - William Pitt
Old 02-17-2009, 09:21 AM
I just tried pinging the external IP of my router and it timed out. I did a tracert and it showed the DNS along with the correct IP but couldn't reach the destination. It's like my router is invisible.
--clutch-monkey
Old 02-17-2009, 11:10 AM
The Unsettler
You need to enable remote management of the router from inside 1st.
Most routers are set that way these days.
May also have ping reply turned off by default.
If you can ping something then you know it's there and can run a portscan looking for vulnerability.
No reason for a home router to respond by default.
"Brandon Won"
Old 02-17-2009, 11:11 AM
So that shouldn't affect my abiility to set up the vnc portion right?
--clutch-monkey
Old 02-17-2009, 11:15 AM
The firewall at your office may also be restricting your connection. Where I work many ports are blocked from passing traffic both ways.
1987 GP White 930
1977 Ford Bronco
Old 02-17-2009, 11:17 AM
That may be true. I know there are vnc users here though so at the moment I have to assume they are not blocking the ports.
--clutch-monkey
Old 02-17-2009, 11:18 AM
The Unsettler
Possibly but not the 1st thing I'd look at.
"Brandon Won"
Team California
speeder's Avatar
Since we have the attention of knowledgeable people here, anyone know how to make a Mac sync w/ Blackberry as modem? I know that PCs can use BBs as modems but Macs are trickier. I have a G4 laptop w/ Leopard and it recognises my BB on the little phone icon near the airport, etc., on top of screen but it won't connect.
Denis
Old 02-17-2009, 01:12 PM
Semper drive!
rcecale's Avatar
Denis,
the easiest way to connect a Mac to a BB is by selling the Mac and buying a PC!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 02-17-2009, 03:26 PM
The Unsettler
Hmm,
Which model BlackBerry?
It's usually just making sure you have the correct modem driver.
"Brandon Won"
Old 02-17-2009, 03:41 PM
Ok, I've done all of the suggestions and still no luck. I also verified that my company does not block the ports as we have many users that use RealVNC daily. I turned on remote management but still can't connect to the router. Any more ideas to try?????
--clutch-monkey
Old 02-18-2009, 07:00 AM
The Unsettler
Who is your ISP? Do they block VNC traffic?
What VNC client are you using on the PC? Some require SSH tunneling to be enabled on the other (OS X) side.
You could try a third party VNC server like Vine
If you want to PM me the details for your VNC connection from the outside I can test it from a Mac. Might help to localize the issue.
"Brandon Won"
Old 02-18-2009, 07:21 AM
Family Values
KaptKaos's Avatar
I just checked and LogMeIn works with Macs and its FREE.
Here's the link:
https://secure.logmein.com/products/free/
If you can't make it work any other way, why not try this? It accomplishes your goals, although it may not be as "techie" as you'd like.
- Joe
Old 02-18-2009, 07:26 AM
The Unsettler
Here's the link:
Need to download to verify but looks to me like they are acting as a gateway/portal which means you are passing your traffic thru them. Not sure if I'm entirely comfortable with that idea.
They also seem to have some screwiness going on with their client/server. http://community.logmein.com/logmein/board?board.id=48
There is nothing really Techie about what he is trying to do. 90% of the time this stuff works out of the box. The times it does not can be a bit trying.
Had a similar issue with 2 of my linux web servers. No one in my group had issues with box 1, but for some reason box 2 was only accessible from my laptop. Could not hit it from any of the other 6 or so boxes that could hit server 1.
Both servers are identical hardware running the same version of SUSE.
We got it worked out but it took a bit.
"Brandon Won"
Old 02-18-2009, 07:45 AM
Here's the link:
That site is blocked by the company.
--clutch-monkey
Old 02-18-2009, 07:52 AM
I don't know if the ISP blocks it.
I'm using UltraVNC on the Windows box.
I currently have osxvnc (Vine) running on the Mac and it shows internal and external as green (good)
Let me try some others things first.
Answer to your questions.
--clutch-monkey
Old 02-18-2009, 07:57 AM
