HVAC-Natural Gas or Heat Pump?
We live in the mid-Atlantic region (Maryland) and are strongly considering updating our heating and AC. The house is approx.2,400 sq feet. The heating system is an electric heat pump sized for a house of about 2,000 sq ft (we had an addition built last year and expected to have to do something with the heating /ac at some point; the $650 electric bill last month was a great motivator).
My basic question is, is gas more efficient than electric? Does anyone have electric as the primary heat source and gas as back-up heat? Does anyone have an opinion as to which brands are better? The brands in question are either Carrier, Trane or Rheem.Thanks for any insight. Mike |
I only have opinions, but here goes: IMHO you're a bit far north to rely solely on a heat pump for heat. They really lose efficiency at low temps and the auxiliary heat (not very efficient and costly) will be called upon too often. I've had both and I would not trade gas heat for anything. Gas heat is relatively expensive (but in your case maybe not), but it heats the house faster and the temps coming out of the vents are actually warm. It's very nice.
Our house is 2400 sq ft in Knoxville, TN (probably slightly warmer on average) and our combination gas/electricity bills are less than half what you are seeing.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Bandwidth AbUser
Mike, I agree with what Mike said.
Jim R. |
Go gas fired. I live in Atlanta and I feel we get too many sub 20 degree days for a heat pump. Maybe if you were in Florida.
UnRegistered User
As mentioned above, heat pumps do a great job as long as they have warm ambient temperatures to work with. As the temperatures drop so does the ability for the unit to heat effectively.
Look at getting a high efficiency nat gas furnace and a matched coil and condensing unit. That ought to cut down on your monthly output for energy. It isn't going to be cheap, but the payback time will be short with the amount you are spending each month on your electric bill. Keep in mind, that monthly bill also includes the rest of the operating expenses of the house, lights, laundry etc... What amount do you spend for power when you are not running the heat pump for heating or cooling? Check your past bills for the lowest months for consumption, that should give you an idea as to how much it is costing to run the current system and what a projected payback time would be. If your due to replace the old system anyway due to repairs or deferred maintenance, just spend the money and go all new. It will save you $$ during the cooling season too.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Ground source heat pump maybe?
canna change law physics
Since you have a forced air setup, you should be able to get it retrofitted for a Natural Gas burner. This assumes you have natural gas in your home. If you don't it may be costly to run the gas line. In the long run, changing your heating system and hot water heaters will pay you back.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
So, gas heat in Alabama is more expensive than a heat pump. But it sure is nice...
(the shotguns)
Live in Md as well and my understanding is a hybrid unit (gas below xx deg., heat pump above) is the most efficient.
We have gas, it feels good, costs a lot, and is very, very dangerous. I say that because it can a)blow up, b)poison everyone in the home, c)...well who needs c when a and b are what they are.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
(the shotguns)
I expect it had more to do with the design of the house in Alabama, than the heat pump. Or, you were merely heating from outside temps of 55-60 outside.
A heat pump is nothing more than an Air Conditioner run backwards. If you have a local heat sink (water) the system can work very well. If you are using air as the heat sink, you get a double hit. As the temperature differential increases, you need to transfer more heat, but the heat sink becomes less efficient. San Diego is an ideal place for a Heat Pump. While I lived there, the outside temp at my house never went below 39 F in the winter, and never above 85 in the summer. And in the winter, the temp would reach 60-65 during the day and in the summer, it would drop to 65 at night. You would run the system a minimal amount of time, and you have a significant section of the day where the delta is so small, that a heat pump is very very good. For heating, the problem is that below about 20F outside temp, the effectiveness and therefore cost of operating the heat pump exceeds that of running electric resistance heating. And since NG runs about 1/3rd the cost of electric resistance heating, the break point for heatpump vs. NG is somewhere between 40-50 F.
Gasoline is far more dangerous than Natural Gas, since it takes a more energetic spark to ignite methane than gasoline vapors. Have you stopped running your gasoline car because it is dangerous? NG produces almost zero CO, without any controls. You car needs special controls and a double CAT to meet emmision standards.
Bandwidth AbUser
red, Mike's area gets dirt cheap electricity from TVA. Your area likely gets dirt cheap natural gas. Here in the Mid-Atlantic, it's all expensive.
I think that it might be a bit cheaper to run natural gas for heat, instead of using electric heat to take over for temps below the range of the heat pump. Just my opinion.
Jim R. |
Go with natural gas, or supplement with a pellet or wood stove. BGE dinged me for ~$350 last month. Ouch.
I lived most of my life in Upstate NY and Western MA. I've had houses and apt buildings use a variety of heat sources. Maybe his $/kWh is extremely low. But most of us are paying much more than $0.10/kWh. And apts in upstate NY which used electric heat, were always much more expensive to heat, by a factor of 3, than those using natural gas. I converted my apt units to use NG, to make it easier to rent my places.
(the shotguns)
100% more than do with heat pumps.
So, when are you giving up your car? They are far more dangerous than a NG heater.
From Wiki
Rates when I was in Alabama (especially the house with the heat pump) were around $.06/kWh. They're well below $.10/kWh even now.
I live in Maryland. We have two heat pumps. When it gets really cold outside they can't keep up. So I installed a Jotul stove (looks like a woodstove but runs on propane) for supplemental heating.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
