I knew someone that had a similar issue. Ended up having a pin running down the finger for 2 months. Be careful around Orth Surgeons, incredible Docs overall (I owe a lot to mine, specifically being able to use my left thumb) but I have to wonder about anyone that takes a drill to another persons body on a daily basis.
Looks like a broken tendon. Go to your local ER and have it assessed. Probably will end up with a splint and a erfereal to an orthopedic surgeon. Good luck!
Good luck. I had a similar thing with my thumb. My thumb stuck straight out. It wasn't a problem but cars kept stopping and asking me if I wanted a lift.
I felt a squigly thing in my forearm and it was my thumb tendon broken off. I got an operation where they reconnected it but it was an awful physio rehab - very painful. It's 90% ok now but can hurt a bit at times, and this is 25 years later. |
Looks like boutonniere deformity.
Yes. See a Doc ASAP. I blew out my bicep a month ago and the Orthopod said that time is critical if it is a tendon issue. Had my distal repair 3 weeks ago. Still can't extend my fingers-radial nerve palsy. Days, weeks, months nobody knows.. Bottom line- get it seen!
Looks like a classic case of trigger finger. Happened to me once, took a cortisone injection, into the effected area. End of problem. Don't believe them when they tell you that the needle "only hurts a bit".
http://orthoinfo.aaos.org/topic.cfm?topic=A00024 |
Had it checked today, said it is broken and now in a splint and they said to get it X-Rayed and comeback in 4 weeks:)
Leg is getting better too. |
Byron, please tell me the finger wasn't attached to your your drinking arm :D
Huh, broken is usually bruised.
I suspect Byron von D can drink adequately with his off hand |
Too bad, Byron. That bent finger was the perfect shape for some of those questionable ladies you hang out with.
how did you break it? |
It is my left and I hadn't had anything to drink all week:eek: Quote:
Yes sir I canhttp://forums.pelicanparts.com/support/smileys/wat6.gif Why don't I feel any pain?? Quote:
Well let’s thank THE BIG GUY for giving us redundant drinking arms!
I’m not quit as efficient with the left, as I'm a righty :D |
Finger upate
Still in a splint, but not broken, but tendon. Now they want me to have an MRI on my finger. |
heat and Kroil. repeat as needed.
Just noticed this thread, How do you get yourself in these predicaments? Haven't even finished healing up the leg and now you have finger issues? :>) How's the leg doing?
Karl 88 Targa |
I swear, if I was a car, I would part myself out.....
Are you open to trades? :) Have a big toe that locks up straight from time to time - try getting shoes on with a sgt. Hulka that wont bend. Btw, you are going to look like some kind of contorsionist picking buggers at the stop light! |
| All times are GMT -8. The time now is 09:10 AM. |
