Nut Removers
I suspect the title may be keeping some folks from clicking on this thread. I'm talking about the nut/bolt removers that look like a socket where the inside is flower shaped. I'm the newest convert. These things are amazing.
![]() I was taking the wheels off of my wifes car but came across a stubborn nut. They are 17mm nuts. I ended up pounding a 16mm 6pt socket onto the nut and when I put a breaker bar on it, the outside of the nut became round. I remembered seeing these things before and went to HD and bought a set. Wow, I put the thing on the nut and turned and the nut came right off. Wow is all I can say. If you don't have a set, you should get some.
Craftsman makes 'em as well...one set has a cool tist...say you're trying to take off a nut from a long threaded bolt They make a set open all the way through, going over a threaded bolt. you apply the force to remove with an open end or a crescent wrench...Think Sears calls these "bolt-outs"...
Same principle...yep, they work slick. Especially after applying some PB Blaster...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
meister member
Have a set but haven't used them yet.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Slackerous Maximus
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Detached Member
I have the "bolt out" ones from Sears, as sold on TV by BoB Vila, they flat out work. I wish they were around 30 y/o.
Hugh |
Soldier of Fortune
I'm wondering what kind of wrenches/sockets you're using prior to needing these devices(?). Have I been doing something wrong not to have a need for them in (gasp) 50 years of nut removal?
Jim
down to jap bikes that run and a dead Norton |
Soldier of Fortune
Typically, most of the bolts I come across that require a bolt-out have been mucked-up by the previous owner or their dim-bulb "mechanic". |
I think the previous folks that put the lugnut on did it with an impact. The nuts are aftermarket and are small diameter, and soft. I think it was a combination of things that led to it. I also don't have any heat to put on the nut. That probably would have helped. I've never actually used heat to get a nut/bolt out. I normally do pretty well getting things apart too, but then I only have about 22 years of nut removal exp.
The title begged for that response. My first response was the photo of my ex. Now she could bust your nuts.
Dan |
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler... "The sea merely lies in wait for the innocent but it stalks the unwary." |
