Nut Removers
I suspect the title may be keeping some folks from clicking on this thread. I'm talking about the nut/bolt removers that look like a socket where the inside is flower shaped. I'm the newest convert. These things are amazing.
I was taking the wheels off of my wifes car but came across a stubborn nut. They are 17mm nuts. I ended up pounding a 16mm 6pt socket onto the nut and when I put a breaker bar on it, the outside of the nut became round. I remembered seeing these things before and went to HD and bought a set. Wow, I put the thing on the nut and turned and the nut came right off. Wow is all I can say.
If you don't have a set, you should get some.
Old 03-28-2009, 06:22 PM
pwd72s's Avatar
Craftsman makes 'em as well...one set has a cool tist...say you're trying to take off a nut from a long threaded bolt They make a set open all the way through, going over a threaded bolt. you apply the force to remove with an open end or a crescent wrench...Think Sears calls these "bolt-outs"...
Same principle...yep, they work slick. Especially after applying some PB Blaster...
Old 03-28-2009, 06:28 PM
meister member
speedracing944's Avatar
Have a set but haven't used them yet.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-28-2009, 06:34 PM
Slackerous Maximus
HardDrive's Avatar
2014 Cayman S, PDK
Old 03-28-2009, 06:37 PM
Yeah, I think several folks make them. I just happen to live about a half mile from an HD who had the set above and several miles from the local Sears which is in a mall. I'd have preferred the craftsman, but I'm sure these will be fine.
Old 03-28-2009, 06:38 PM
Detached Member
Hugh R's Avatar
I have the "bolt out" ones from Sears, as sold on TV by BoB Vila, they flat out work. I wish they were around 30 y/o.
Hugh
Old 03-28-2009, 06:50 PM
KarlCarrera's Avatar
Da** it, don't do that, now I have CC and 7 on the keyboard
Karl
88 Targa
Originally Posted by HardDrive View Post
Old 03-28-2009, 07:15 PM
Soldier of Fortune
DasBoot's Avatar
That's not a nut remover...that's a nut shrinker!
Old 03-28-2009, 07:39 PM
I'm wondering what kind of wrenches/sockets you're using prior to needing these devices(?). Have I been doing something wrong not to have a need for them in (gasp) 50 years of nut removal?
Jim
down to jap bikes that run and a dead Norton
Old 03-28-2009, 07:56 PM
Soldier of Fortune
DasBoot's Avatar
Jim
One of my front end (ride height) adjusters was stuck and eventually stripped when I attempted to remove it. Most likely hadn't been touched since 1971. I used my favorite penetrating oil (AeroKroil) and heat to no avail. Bolt-out saved the day.
Typically, most of the bolts I come across that require a bolt-out have been mucked-up by the previous owner or their dim-bulb "mechanic".
Old 03-28-2009, 08:09 PM
Jim
Well, today when I started, it was first a craftsman 6 point 17mm, then I pounded a 6 point 16mm on after that.
I think the previous folks that put the lugnut on did it with an impact. The nuts are aftermarket and are small diameter, and soft. I think it was a combination of things that led to it. I also don't have any heat to put on the nut. That probably would have helped. I've never actually used heat to get a nut/bolt out.
I normally do pretty well getting things apart too, but then I only have about 22 years of nut removal exp.
Old 03-28-2009, 08:44 PM
Danimal16's Avatar
The title begged for that response. My first response was the photo of my ex. Now she could bust your nuts.
Dan
Old 03-29-2009, 05:53 AM
billyboy's Avatar
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 03-29-2009, 07:41 AM
