Glorified Babysitter
BeerBurner's Avatar
Replacing radiator on '05 Civic
A good friend of mine has an '05 Civic that the dealer says needs a new radiator but they want $800 for it. I told her I could do it for her but I don't know if it's a straight-forward procedure or if there are any "gotcha's" in it, and an internet search only gave me procedures on older Civics.
Does anyone have any experience, tips or places I could look before I agree to doing this?
Thanks!
BB.
'87 Porsche 944 (toy)
'90 Miata (daily driver)
'04 PT Cruiser (her's)
"Sometimes you're the windshield... sometimes you're the bug."
Old 03-29-2009, 06:01 AM
Just thinking out loud
mattdavis11's Avatar
I've replaced a couple of condensers on a few civics, but not a radiator. Mind you these were 96-02 or there abouts, but not much has changed. It should be pretty simple. Move the fans out of the way, take the hoses off, unbolt the upper mounting brackets and pull it up and out. You'll need a 10mm for sure. There's a lot of room since the motor is sideways. The condenser takes about 10 minutes to pull, the radiator should take less.
91 FJ80
84 Ram Charger (now gone)
Old 03-29-2009, 07:21 AM
BeerBurner's Avatar
I did finally hear from someone who explained the procedure to me and said it was identical to my Mazda, save for having the slushbox cooler whose lines I'll have to muck with.
Thanks for the response!
BB.
Old 03-30-2009, 03:26 AM
Laneco's Avatar
A three year old civic that needs a new radiator? Hmmm.
Quite a bit of stuff available aftermarket for civics. When we've put them together after crashes, we usually buy an aftermarket radiator. They seem to run about $50 to $80 or so and work just fine.
angela
Hello
Old 03-30-2009, 08:12 AM
fireant911's Avatar
BeerBurner,
I went to a junkyard to get another radiator for my '95 Civic as it had cracked and was leaking. The junkyard had no used radiators but kept new replacement (aftermarket) radiators on-hand (these must apparently fail at a rather high rate). The price, as my memory serves me, as about $100... installation was simple and the replacement unit has done well. Take a peek a the Hayne's manual for the '05 Civic - my guess it is straightforward. My wife has an '08 Civic and I have not looked at this setup.
Daryl G.
1981 911 SC - sold 06/29/12
Old 03-30-2009, 11:45 AM
BeerBurner's Avatar
I've been trying to figure out if this was an isolated thing or something that Honda didn't get quite right. Not that I've really taken the time to research it...
BB.
Old 03-31-2009, 03:36 AM
Team California
speeder's Avatar
Replacing the radiator on most any vehicle is pretty straight-forward, the problem is always wondering how the previous driver discovered that they needed a radiator. Usually it was when the car over-heated on the freeway. I look at ads all the time for vehicles that just "need a radiator" or a head gasket and none of them ever over-heated, they just happened to notice it leaking.
Denis
Old 03-31-2009, 09:20 AM
Air Medal or two
afterburn 549's Avatar
The OEM stuff is barley big enough...I would call a rad shop and NOT get a OEM !
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-31-2009, 09:54 AM
one of gods prototypes
bell's Avatar
My wifeys old 06 civic was pretty darn simple, should olny take an hour or so max. Is it leaking? What was the dealers reason for it being bad? Is there rust in the coolant? (That's a sign of just water and no antifreeze and should have it flushed if so, rusty water can clog the veins in a radiator over time)
Brought to you by Carl's Jr.
Old 03-31-2009, 10:52 AM
