Banned
Ideas for magnetizing a wall?
I want to magnetize an 8'x8' wall in my studio. I've primed it with 5 coats of Rustoleum magnetic primer, which isn't satisfactory. The magnets barely stick to it--even the rare earth magnets. I'm not opposed to mounting steel strips--maybe 1 every foot--horizontally, the length of the wall. They're expensive. I'm looking to you nerds for a cost effective solution. Needs to look graphic and slick. I don't want to use cork and push pins. Help an idiot out for Christ sakes.
Non Compos Mentis
Steel roofing shingles? Galvanized steel corregated panels?
Either could be made to look funky. |
So you really need a wall that magnets will stick to....not a wall that is magnetic?
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." |
Double post for some reason
Maybe put up a sheet of galvanized steel of something like this:
http://www.onlinemetals.com/merchant.cfm?pid=13526&step=4&id=1004&top_cat=849 If you did it right maybe it would look modern or artsy
what do you want to hang on it? Spacing? Does the entire 8x8 area need to be metallic?
Platinum Member
Buy 4x8 sheets galvanized from plumbing/heating supply house. Not expensive. The stuff they use to bend ductwork.
Slumlord
Or get it cut into strips and glue the strips on where you need to place magnets.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Banned
Banned
I don't know if you can visualize this but I don't have any pics. When I opened my first solo office, I rented a space that was once the showroom for Viking Range. It was in an old building with 16' ceilings remodeled to look like a NY loft...track lighting, exposed HVAC duct work, old unpainted brick walls, etc. My reception area looked like an art gallery with a huge tall, monolithic, white painted 16' tall wall. I need some type of dramatic art work but was broke and it wasn't in the budget.
I went to a local metal fabrication place that made various industrial metal products. I asked to look in their scrap/recycle piles for something interesting to create "found" sculpture art. They used a computerized plasma cutter to cut metal sheets for various components. I found a few sheets of relatively thin flat metal that they had cut 18" circles out of that were used to weld in the bottom of some type of tank. Although it was 10' x 6' it was relaticely light since the compuer plotted the cuts for maximum material use. I took it back to my office and mounted ot to the wall willvarious other metal scraps (contrasting aluminum and stainless) behind the circle cutouts. It was very modern/industrial looking and people thought it was a high priced sculpture. When I left the office a lady came by and offered to buy it from me to use as sculpture for the side of her pool house. I just gave it to her. It had cost me nada. Last I heard my art was still on display some 10 years later.
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." Last edited by Dueller; 05-06-2009 at 05:21 PM.. |
Take a magnet with you...I don't think true stainless is magnetic.
Dept store Quartermaster
You can buy thin coated (just about any color)steel sheet from any metals supply house/service center. Just call one in your local pages, they sell to the public.
Cornpoppin' Pony Soldier |
You're in Chicago(ish) right? Call Central Steel & Wire 1-800-621-8510 and tell them what you want. They'll cut it to size and deliver.
UFLYICU
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Now in 993 land ...
Ferromagnetic is the word you were looking for.
![]() George |
Banned
Velcro man, Velcro...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Just thinking out loud
It would be a whole lot cooler to magnetize the wall and use random metallic objects to hold ***** up. A piston here, crank bearing there. That's the ticket.
83 944 91 FJ80 84 Ram Charger (now gone) |
The dark mag paint is pretty good, we used it in the past, but it does limit the strength of the magnets that you can use and hence the weight you can pin up.
We use enamelled steel panels on our walls here in the studio with pretty hefty magnets to hold up display boards and drawings. The enamel protects the steel panle and does not scratch so they look good for years. Bare galvanised steel will show damage after a couple of years.
Share with me. Teach me something I didn't know. Make me think. But don't make me a bit player in your passion play of egotism. Dueller. 13/03/09 |
