"O"man(are we in trouble)
widgeon13's Avatar
Apple memory upgrade?
How much improvement will I see in my MacPro 2.2 going from 2G to 4G of memory, anything or will performance be the same? Cost is only $50 or so, should I do it?
Old 05-26-2009, 04:19 AM
jeffgrant's Avatar
Depends on what apps you run, but to me it's a no-brainer.
Every Mac I have has maxed out memory, and they all run faster as a result.
$0.02
Old 05-26-2009, 04:25 AM
widgeon13's Avatar
Don't run much other than normal office suite and iworks stuff and the normal software that came preloaded.
Old 05-26-2009, 04:28 AM
I'm getting 4GB in the mail today. I will let you know if I see a difference. I know it will make a huge difference when I run VMWare. I have a new aluminum MacBook 2.0.
Neil
'73 911S targa
Old 05-26-2009, 05:37 AM
The Unsettler
stomachmonkey's Avatar
RAM has never been cheaper. Buy as much as you can afford.
"I want my two dollars"
"Brandon Won"
Old 05-26-2009, 05:52 AM
Danimal16's Avatar
Maxed out my MacBook Pro and noticed a big improvement, particularly in dealing with photos.
Dan
Old 05-26-2009, 06:31 AM
widgeon13's Avatar
Any tricky installation issues as well?? Thanks
Old 05-26-2009, 07:19 AM
drunk and stupid
HHI944's Avatar
I'm curious to know how installation goes also. I bought one right after they came out and now I'm feeling the memory upgrade itch. Any easier or harder than on the last gen White MacBooks?
Old 05-26-2009, 07:28 AM
The Unsettler
MacPro is a Desktop unit and adding RAM is cake.
RAM gets installed on trays that simply slide in/out.
MacBook Pro is also cake, remove battery, remove a couple of screws. RAM goes in at a slight angle, you should be able to get it seated in the slot and it will rock back n forth. Then gently lay it into place so the clips click.
"Brandon Won"
Old 05-26-2009, 07:41 AM
Actually, ram prices seem to be going up, at least Mac ram. My reference point are the prices at Other World Computing. A 4 Gb module for my PowerMac G5 was $42 a couple of months ago. Today's price is $60.
Sherwood
Old 05-26-2009, 08:58 AM
