What would be a better Autocross car?
I am looking for a beater to run autocross in to save the paint on my precious 944. I have kinda narrowed my sights on a 914 or a MkI GTI. I know the cost of entry will be close on both and the parts will be cheaper for the GTI. But in the end will the handling of the 914 make the cost worth it? Or should I just buy a good GTI put some suspension on and drive it like I stole it?
Tough question. I'd say both the 944 and 914 have an edge on the VW GTI due to the rwd layout.
But the GTI has more power than the 914, unless you are seeking a modified 914. I can tell you at the last NNJR PCA autocross, a modified 914 took the top honors (Fastest Time of the Day). Smokin' hot driver, and a well setup car. I have NEVER seen a GTI take FTD in any autocross. -Z-man. |
I'd say get a beater 944. There are tons for sale for $3k and under, you're familiar with how they handle, and you'll have lots of competition. If you're in PCA, compete in GS, GP or 944 Spec and you'll have a serious load of fun.
A reasonable 914 won't be as cheap or competitive as a 944. |
Not sure what risk there is to paint in an autocross but the 914 would wax a 944 or GTI.
JR |
I retract what I said about 944's beating 914's. All things being equal, the 914 should beat the 944. Looking back at the results of my last AX I see that 914's took 5th (AM), 13th (AI), 16th (AI) fastest. Fastest 944 was 19th (944 Spec).
+3, the chance to mess up your paint is about as likely as hitting a zebra
Check the history of Porsche Parade autocrosses. More often than not, the TTOD car is a 914...
Check this out:
http://www.914club.com/bbs2/index.php?showtopic=143731 This guy has built a great AX car out of a 914, and is priced at, what I think, is a steal. |
What, no miata option (which would be better than the 914 and GTI)? Cheap, reliable (bottom end from a turbo car similar to an SC), cheaper parts, lots of aftermarket support including factory support. You can purchase parts from Mazda's racing stuff if you've got 2 autoX under your belt, I think is the rule.
When miata's show up at autox I attend, they leave everyone for dead. Between your choices, 914 would have to be the way to go... but your paint should be fine in an autox...
914s perform well for a 40 year old design but unless you want to spend big dollars and time you won't be winning your class at a SCCA a/x. Ask me how I know.;)
get a go cart
Can't the 914 take a larger porsche motor?
Lots of good ideas here, but they all depend on one unanswered question:
What class do you want to run? |
Just drive your 944 and stop being a pansy, cars are meant to be driven.
I Autocrossed my 911 quite a few times I did less damage to the paint hitting cones than I do to it when I took road trips to the mountains with it. I AX my RX7, which when I started 8 years ago had pristine paint. Guess what, the paint is not shot from Autocrossing its shot from being old. I am about to drop it off for a repaint and I fully intend on AXing it once its done. The money you will drop on another car, sorting it out mechanically, then upgrading it to be competitive (where you could have done the same to the 944) then buy tires for it....... yada.... You could get the 944 painted again and again. I vote AX the 944 and stop worrying about the cone rash, it waxes off. Even better don't hit them. :D |
TTOD 914's are usually flat out GT class race cars. |
I am with milt on this one, If you are looking for a budget auto x car, the GTI is the way to go. While a sorted 914 is a super fast auto cross car, you will spend a small fortune getting it there. Unless you buy someones already set up car. Stock 4 cyl 914's were pretty slow at our local auto crosses.
I hand grenaded my sc a while back, and while I was reassembling ( 2 years), I ran a 1991 16V GTI. I think I spent about $1500.00 on it , to set it up, and it was a blast to drive, easy to drive, and was fairly competive. I ran the snot out of it for 2 seasons, broke one motor mount, and ate one set of tires. I think my set up was real simple, H@R sport springs, koni sports, a large rear addco sway bar, lots of negative camber ( $15 crash bolts ) and victoracers. While I never FTD'd, I was usually pretty close to the fast guys, and this car was an absoloute blast . Add a limited slip, and you are really talking. Just my .02 |
For cheap AutoX, I'm under the impression that Miatas are the way to go. No matter what though, cones won't hurt your car. Unless you think your car is like a concours car or something.
| All times are GMT -8. The time now is 08:52 AM. |
