Scott R's Avatar
Anyone every install their own attic fan?
I want one, I have a pre-wired blank plate exactly below where I would think an attic fan should go. How hard of a job is this? Anyone done it?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-13-2009, 11:06 AM
Did you get the memo?
onewhippedpuppy's Avatar
No real big deal. Cut hole with circular saw or sawzall, leaving plenty of extra shingle to trim later. Install fan in hole, flash, trim shingles and seal/nail down. I need to put one in, but my roof is 40 ft high and steep. Yeah, I'm a big sissy when it comes to heights.
Old 06-13-2009, 11:19 AM
Don't cut a roof truss like the PO in my house did.
Rick
88 Cab
Are we talking whole house fan that vents to the attic or a fan to aid the gable and ridge vents?
Rick
88 Cab
Old 06-13-2009, 11:21 AM
Scott R's Avatar
I'm looking for a ceiling mounted fan that's flush with the ceiling and draws into the attic. The way I see this project is, get the fan, cut the ceiling, and then wire it up?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-13-2009, 12:29 PM
Zeke's Avatar
That's a whole house fan. Most will require cutting at least one ceiling joist and heading off at each side. It can be wired to a switch, timer, timer switch or t-stat switch. Be sure to wire in a cut off switch for safety.
Old 06-13-2009, 12:37 PM
If it is a pre-made roof truss, common in the midwest, the bottom member of those things are under tension.
If I were doing it and it required more than the rafter spacing (24"??) I would build a box and mount it on top of that.
On mine it looks like the guy wanted it centered in the hallway, cut the truss and put some 2x's in like a header. Looks like they pulled out 1/2 inch.
Rick
88 Cab
Old 06-13-2009, 03:23 PM
Zeke's Avatar
Yeah, I'd not cut a truss. But, there should be a bearing wall near the hallway where most of these things are installed. The other way to look at how forces affect a truss is to think of them holding the roof up and not always just holding the ceiling span. Still, the bottom chord is in tension, as you say, and must be tied.
Old 06-13-2009, 03:38 PM
Scott R's Avatar
basically, not knowing what a "truss" is I'm already in over my head
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-13-2009, 03:58 PM
You indeed may be, but there is an alternative.
There are whole house fans which fit inside of the trusses and use multiple smaller fans rather than a large one. They have insulated mechanical lids which open and close when you hit the switch.
Randy
'87 911 Targa
'17 Macan GTS
Old 06-13-2009, 04:16 PM
Senior Member
Its easy and a very good mod to the house. Bought it at Home Depot with a discount and a friend of mine and I installed it in a morning. Biggest hassle was finding 110v AC in the attic (it had 220vAC for the A/C) and sweeping up the insulation that fell out of the hole.
I put it in 4-5 years on and it runs all the time when the temps are under 100 over here. Its on right now, when I would otherwise have the A/C turned on as its in the 90's over here.
There was an "Ask This Old House" That covered exactly this. Can't find it on their site tho.
Old 06-13-2009, 04:26 PM
Scott R's Avatar
That's the easy part for me, the builder left me 110V wiring in the exact spot you would put the fan.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-13-2009, 05:31 PM
Detached Member
Hugh R's Avatar
Get a variable speed one, not the three speed one. If it's near your bedroom door, run romex, or metal flex to another location away from your bedroom door. Put it near the kids room. They work well, I used to have one in my old house. Make sure a window is open, or you'll pull the ashes out of the fireplace as it tries to pull air into the house.
Hugh
Old 06-13-2009, 05:37 PM
Senior Member
Scott,
Hugh is spot on. Mine is a two speed and there are times I would love to have a three speed but thats life.
Another thing to look at is to install a timer switch on the fan, so that you can turn it on and have it run while you are sleeping, yet turn off in the middle of the night when not needed.
Joe
Old 06-13-2009, 05:45 PM
Scott R's Avatar
I don't have any kids yet, but I'm trying.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-13-2009, 05:46 PM
Senior Member
It does cover up the "moaning sounds" very well...
Old 06-13-2009, 06:18 PM
Parrothead member
VINMAN's Avatar
If you install one make sure you have adequate venting out of the attic. Gable end , or roof vents. Ive seen installations where the CFMs on the fan was way to high for the attic vents.
Vinny
Old 06-13-2009, 06:23 PM
Scott R's Avatar
I bet I don't, my soffets are vented, that's about it.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-13-2009, 07:42 PM
notmytarga's Avatar
I have installed one of these:
http://www.wholehousefan.com/PRODUCTS/HV1600-GR.html
In two houses now. They make more sense than a high flow fan that is poorly insulated (you cover the attic side in the winter ideally) and cools the house immediately with air exchange. Once you shut the big ones off because they are so high flow the CONTENTS of your house heat the air back up.
The fan systems on the site above use little power - lower flow - and can run as long as you want - which cools off the entire contents (furniture, floors, walls etc) of the house by morning.
They fit is smaller framing too. I would have gotten a bigger one that has the fan further into the attic if I know I needed a bigger unit to match the performance in my smaller house.
Old 06-13-2009, 10:11 PM
