Band.
Well, my wall/workbench thing is progressing reasonably.
I'm going to make a workbench/shelf here: ![]() ![]() I'm going to put a nice thick piece of plywood up there, and maybe run it up the wall a few inches, backsplash-style, and I'd like to: 1. Either treat the wood or paint it with something chemical-resistant, or 2. put some kind of laminate or something on it. to protect from carb cleaner, brake cleaner, etc. etc. I'd rather do option #1, because it's easier. Does anyone recommend or know of any kind of finish I can put on bare plywood to protect it from garage chemicals? I don't need style-points, just functionality. Thanks!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
If you could get a piece of steel bent to use as a top. Have it bent to hang down in the front and bent up to make a nice lip in the back. Then you have a chemical resistant top that can be cleaned with a razor blade or scotch brite pad.
Not sure what your trying to protect it from. The beauty of a plywood top is that it is cheap and replaceable. You could rub some tung oil on it to allow any spilled liquids to puddle long enough for you to wipe it up.
Oil it up, use it for 20-30 years, then replace it with a fresh piece if the mood suits you. I like to use a couple of layers of 3/4" so it doesn't bounce when you pound on it with a bfh. The other trick is to simply flip the top over when it gets nasty.
Randy '87 911 Targa '17 Macan GTS |
Personally, I like the laminate tops that they sell at Home Depot. They have a small (4") back splash curved into the top and you just cut the top for the correct length. You could add a sheet of plywood underneath for strength. They have a variety of styles/patterns and you could get something that looks industrial for the shop.
Door...
I'll soon be making a small bench in my temporary garage.
By small I mean a solid wood blank door from Home Depot on a 4"x4" base. Bench stains give character & tell stories. ![]() . I like to keep big sheets of cardboard around for benchtop cover on messy jobs. Tung oil...good idea...thanks. . Happy Benching.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Band.
Me too, but those all measure about 25-26" deep, and my spot here is only about 22", so it's gonna need to be a DIY thing.
Band.
Funny, I thought of tung oil too. Not real tung oil, but just the can stuff.
I have a piece of masonite covering my bench top. When it gets too worn, it can be replaced. Cheap and easy.......
Hugh Lindberg 1972 911 1970 Alfa Romeo 1300 GT Junior |
+2 on Masonite - I put 3 or 4 coats of varnish on mine. Oil won't stain or soak in and lasts for many years......
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Piece of steel will last forever.....
Band.
I'm 37, Sidney. I only need it to last 30 or 40 years.
Well it will do that plenty well. It makes such a nice smooth clean surface. Easy to clean and nothing ever soaks in.
abit off center
Just make sure its big enough for a sleeping bag too! You know the routine "are you ever coming up?"
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Band.
No. No I don't.
That sounds like a pretty awful routine.
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Unconstitutional Patriot
laminate glued to plywood with contact cement. Then, use a router with flush trim bit to clean overhanging laminate. This is very cheap, durable (not affected by chemicals), and very easy to clean.
Platinum Member
you can buy galvanized sheet steel from a heating/ductwork supply house. It is not expensive.
Model Citizen
I vote for the hard masonite over 3/4 ply. A couple of coats of Watco oil, it looks terrific, and cheap and easy to replace. I had some oak strips about 1.5 x 3/8 laying around that I wrapped the edges with, and it looks just great and wears like iron.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Senior Member
Really, really like the copper overlay that Thom (widebody) used in his workshop. Looks great and nice to have at least part of the bench being metal. Grounds, works while welding and so on. Did I say it looks GREAT?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
