What fluid should I use for automatic tranny?
My Lexus 2000 ES300 manual says to use ATF Type T-IV or Dexron III. Which is better?
Thanks.
Fat butt 911, 1987 |
Ahh it's Japanese. Just buy the first one you see in the store. Crap it'll run forever....
Unregistered
IMO Just use either, as long as you follow the manual the tranny should last longer than the rest of the car. |
Any ATF that meets OR EXCEEDS those specs will do fine. I would buy full-synthetic (i.e. Amsoil ATF, or Redline ATF) as it is cheap insurance for such an expensive system.
I would love to put synthetic in there since I can easily find them at autozone, but I affraid it'll leak. I had bad experience with synthetic engine oil on old car. As far as deron III or IV, there only thing I can find is Walmart brand, which I affraid it's bad for the car. Am I worry too much? Any other place I can look for some decent Dexron III?
AutoBahned
ok, what car & what does the owner's manual spec. for it?
many like redline, but it is synthetic IIRC I'd avoid Walmart unless this is an old beater. |
Oh, a flush removes all old fluid, replaces with new. Takes special pumping equipment. A "change" leaves a lot of fluid in the torque converter.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 07-08-2009 at 11:47 PM.. |
abides.
My '88 F250 used Dexron III. You should be able to find it at ANY autoparts store.
The fact that you're bothering to change the transmission fluid puts you miles ahead of most cars in america. I don't think it matters what brand you use.
Graham 1984 Carrera Targa |
Truth...most cars die from other ailments with the installed at the factory auto trans fluid in place...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
ruf, I don't know. Most people don't trust Walmart brand. In fact, I heard multiple time that their engine oil is actually Valvoline oil. I tried it and it reacted different. According to a reputable mechanic, it was a good reaction. On tranny fluid, since it's not that easy to replace, I just want to pick the right fluid and hear opinions so I don't have to get under there again soon.
Targa, Panamera Turbo
Thats easy - For your Lexus - use Toyota Type T IV ATF fluids.
Most domestic history: Tranny fluids can be divied into two major groups - those that contain friction modifiers and those that do not. Friction mods are chemicals that make the fluid more slippery under certain conditions. Until the mid 70's, Ford produced trannys with small frictional surfaces. The bands and clutches had to be applied quickly with high pressure to prevent over heating and wear caused by excessive slippage - this requires a non-friction modified fluid with a higher static of coeefficient of friction than a dynamic coeeficient of friction - in other words the frictional forces between the clutches and bands are greater when there is no reletive motion between the components then when they are slidiong against one another before lock-up AKA the hard shift. GM trannys require a more slippery fluid to permirt a smooth shift without any shudder. When the clutch or band locks ups, the friction mods react to decrease the coefficient of dynamic friction - this allows the use of low clutch and band pressures and more plates in the clutch packs to prevent excessive slippage and heat build-up. Using the wrong fluid in either tranny style will result in poor shift quality and short component life. For Ford model years, use the following spec's fluids: 1949-1960: Type A 1960-1981: Type F 1977-1981: Type CJ 1982-1987: Type H 1988-1992: Mercon 1992-present: Mercon Revised 1997-present: Mercon V For GM model years, use the following spec's fluids: 1949-1966: Type A 1967-1973: Dexron 1974-1991: Dexron II/IID 1992-1994: Dexron IIE 1995-present: Dexron III For Chrysler model years, use the following spec's fluids: Pre 1988: Dexron IID 1988-1997: ATF Plus, ATF +2 1998 - Present: ATF+3 1999 - Present: ATF +4
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
LubeMaster,
wow... worth the wait. Thanks. Can I dig your well knowleage brain one more question? For an automatic Lexus with 110k miles, do you think it's better to use Toyota Type T IV ATF fluids or better to use Dexron III (also recommended in the manual)?
For example, 2004-2007 Saturn V6 VUEs used a Honda V6 and Hondas (horrible) clutch-to-clutch Aisin-type automatic. 2002-2007 Saturn 4 cyl VUEs if they were AWD used a CVT transmission. If I owned, say, a 2007 Saturn VUE (because it has a GM badge right there on the fender), I'd look at your chart and fill it with Dexron III. It would ruin the CVT, quickly. The Honda unit would likely fail too, if it wouldn't anyway. For example, my 2007 Ford F250 Diesel specifies Mercon SP, and says NOT to use Mercon V. For example my 2005 Lincoln Navigator has a ZF 6spd auto trans, not Ford, and does not use Mercon V. If it were only that simple. Check your owner's manual. |
