Computer Gurus, I need HELP!
I won't waste your time with details, but here's my hard drive that doesn't work any more. It was recognized the first time I hooked it up to the SATA external adapter and last night I did it again and it started smoking. The transistor (Green Arrow) was smoking pretty good. Ok, so where would I get a new board for this hard drive? Any one have one laying around? I'll try the manufacture if I can't find one first. If I can get it back on line just to get my data off of it that's all I care about. Can I just change the transistor, but what is it so I make sure to get the right one? Any other ideas or thoughts?
Pics... ![]() ![]() ![]()
Bill 997.2 |
See if you can buy a use drive off Ebay and swap the boards.
Neil '73 911S targa |
So simple, yet I didn't think of that. DUH! That's a great idea. I'll start looking around there and see if I can find one...
EDIT: Do you think any amount of GB would be the same circuit board or should it be the EXACT same drive? I would think any amount of memory wouldn't matter. Right?
Bill 997.2 Last edited by wcc; 07-08-2009 at 02:36 PM.. |
You need the exact drive. What size? I may have one at home. On my iPhone, pix are small.
160GB Model # ST3160828AS PN: 9W2734-133 HDA PN: 100361729 Config: EXD-01 Firmware: 8.04 I think if all those match up it'd work. That would be great if you have one!
Bill 997.2 |
I'll be home in a couple of hours. Will let you know.
Hi Bill,
I don't have a match. These guys have one for $75 http://www.pinnaclemicro.com/computer/dsku.php?g=ST3160828AS&m=Seagate+Technology Do a search and you may find other places that have them. Good luck! Just remove the four screws that hold the PCB on and the board should pull right off. There may be a little resistance from the sticky foam pad underneath.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Senior Member
Not home right now so cannot check but if you do not have anything done by late Friday, pls message me. I have a stack of HD's at home and might have a 160 gig baracuda there.
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Darn! But thanks for looking! I appreciate the link too. I have a friend that's going to hook it up to a dummy computer and see if it recognizes it. If not, then I'm going to order this up and go from there. Everything I've found is more then $75. It's worth it because there are years of family photos on there. I know, I know, I should have been backing them up somewhere Yup, I already had it off that's how I knew the circuit board was replaceable...
Bill 997.2 |
Well I'm not in any hurry so if you can check when you have time I'd appreciate it. I'll PM you this too.
Bill 997.2 |
Senior Member
Bill,
You can also get an adapter that plugs into the HD and cables it right to a USB fitting and plug the HD into any computer. Costs around $20 or so at Fry's or Ebay.
Yes, been there done that. Now it just smokes. Well, there is a possibility (very slight) that I didn't plug the power cord in correctly. I'm saying that the board moved around that caused the short. Oh well, it is what it is. I'll be in touch in a couple of days....
Bill 997.2 |
Thread Tools | |
Rate This Thread | |
