Canucks Fan
Question Home made tools, you got any?
Was on a Garage Journal site and there was a post about guys who made tools for various jobs, Valve spring compressor from modified vice grips, sand blaster from a 45 gal. drum ( 55 gal south of the 49th ), some real cool stuff. I don't have any pics of my home made stuff and can't take any cause I'm not at home but lets see what you guys have done, for your car or shop or what ever. I'm sure there lots of good ideas, post your pic's and share the glory
Old 08-01-2009, 05:55 AM
Cars & Coffee Killer
legion's Avatar
I made myself a little tool kit for gutting catalytic converters.
Tool #1 is a sharpened piece of 3' rebar. That, with a sledge hammer, will break up the cat.
Tool #2 is a modified 1" x 4' box girder. I cut a ½" x 4" slot out of one side. This is used to pull the large/medium chunks out of the exhaust.
Tool #3 is simply a 2" shop vac hose. It is used to collect the dust and medium/small chunks. I often found myself feeding this hose up into the cat, using it to latch on to a chunk too big to go down the hose, and feeding the hose back out and pulling the chunk off the end.
5 liters of VVT fury now
-Chris
Old 08-01-2009, 07:33 AM
notfarnow's Avatar
I made some tools to take off the rad fan on my e300d. The first is just a long rod with an allan key welded to the end, the other is a tool to grip & hold the fan pulley so you can loosen the nut with tool #1. Haaving a welder is great, because it's so much easier top whip up single-use tools like this
'03 Carrera 4s
+ a whole bunch of boats
Old 08-01-2009, 09:11 AM
Hilbilly Deluxe
emcon5's Avatar
We made a valve spring compressor like this one: http://www.pureluckdesign.com/vw/vsc/
I also made a timing belt tensioning tool by welding a couple nails to a piece of angle steel from the scrap bucket. The nails fit in holes on the tensioner pulley.
We made a toe gauge by riveting a small carpenters square and a tape measure to a length of square aluminum tubing.
82 911SC Coupe
GTI Cup #43
Old 08-01-2009, 09:44 AM
I made this welding cart and added a tool box to the top. Killed two birds with one cart.
Old 08-01-2009, 10:02 AM
meister member
speedracing944's Avatar
I worked in the plastics industry for many years an made many of my own tools out of soft brass to eliminate mold scratching.
Brass slide hammer
brass slide hammer using vise grips
clamp on pullers
spring compressors
brass hammers
special wrenches
All sorts of stuff.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-01-2009, 10:19 AM
Gooch1971's Avatar
I have quite a few modified and homeade tools that belonged to my grandfather. I cherish them much more for sentimental reasons than practical ones.
Old 08-01-2009, 04:21 PM
Start rebuilding 911 engines or 915 transmissions and you'll quickly have a bunch of homemade specialized tools as many of the official "factory tools" or suggested standard tool methods are excessive in cost or work poorly, sometimes both.
Old 08-01-2009, 04:28 PM
Zeke's Avatar
Homemade ball joint nut removal too:
Old 08-01-2009, 04:50 PM
Now in 993 land ...
aigel's Avatar
Originally Posted by notfarnow View Post
I have a fan holder for Ford trucks that I made from flat metal with the MIG. Works like a charm and turns out covers a lot of different models.
I once rebuilt a TH350 auto trans and made a lot of the tools along the way. A welder and a grinder and there isn't much you can't make.
George
81 SC (sold)
Old 08-02-2009, 09:33 PM
924slover's Avatar
Ive got a butt load of homemade tools from pulley holders to belt tensioner compressors to a clutch alignment tool for a 924s and 944 made out of an old torque tube. and after dropping many sockets into unreachable places while changing plugs in the 911 we now have an extension pinned to the socket.
the line between bravery and stupidity is a very thin line
74 914 1.8 DD
76 911T
74 914 2.0 track car
Old 08-03-2009, 12:54 AM
elwood-914's Avatar
Scribes I made in Metal Shop in High School.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 08-03-2009, 05:25 AM
n8marx's Avatar
A re-deployed breast pump makes a fantastic brake bleeder.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 08-03-2009, 06:49 AM
Home made oil cooler flushing thingie
Old 08-03-2009, 06:59 AM
Used & Abused
The roof was sagging in the carport. I made some new supports but because they fit so well, they were damn near impossible to twist and lock into place. I needed more leverage and made it.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 08-03-2009, 04:34 PM
Added 4" to my floor jack...
Old 08-03-2009, 06:26 PM
Old 08-03-2009, 06:27 PM
Model Citizen
herr_oberst's Avatar
the first tool is pretty obvious, it's a third hand. Used mostly for soldering, but handy for painting small stuff, that kind of thing.
The second pic needs some explanation; the alt belt on my pickup was slipping, it went on so long that eventually the pulley was worn very smooth, so I built a "bow" with a piece of wood and a section of an old fan belt (small side out) wrapped with 180grit emery cloth. The device can then be used to scuff up the pulley so the belt gets good traction. Worked like a charm
(and the wooden stick in the picture is a lever to help get proper tension.)
Old 08-04-2009, 07:38 AM
Senior Member
Done it for years now and could not get things done without them.
Old 08-04-2009, 08:48 AM
Z-man's Avatar
My two hand made tools:
Tool #1:
Tool #2: (Note: this is just an illustration, not an actual image of the tool):
Tool #1 is used for banging things.
Tool #2 is a multi-purpose tool: purpose one- banging things. Purpose two: poking things, especially when something is thought to be dead.
That's about as creative I can get with making tools....
Now back to our regular serious discussion...
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 08-04-2009, 09:12 AM
