-   -   Hampton Bay Ceiling Fan/Light Voltage Question (http://forums.pelicanparts.com/off-topic-discussions/489740-hampton-bay-ceiling-fan-light-voltage-question.html)
Hugh R 08-04-2009 06:51 PM
I want to move a HB ceiling fan from my bedroom to my patio (it's rated for wet conditions). My question is that the current electrical source is on a heavy duty dimmer for some other lights on the patio. I can use incandescent or dimmable CFLs for the lights, but what about the fan? It's a pull chain job with three speeds and off. Will the use of the dimmer eff up the motor, or not work at all. I can try and run another 110v line, but it would be a pain. Again, because of other dimmable lights on the circuit, I don't want to use a two switch HB two switch dedicated wall switch if I don't have to. Any thoughts? ThanksSmileWavy
peppy 08-04-2009 06:55 PM
I had the same set up in the park house when we moved in (fan on a dimmer switch, fan would not work) I wired the fan directly and the lights are on the dimmer.
Hugh R 08-04-2009 07:06 PM
Thanks, that's kind of what I thought.
LakeCleElum 08-04-2009 08:12 PM
Recently installed one that has a remote control for the fan. Instructions were clear to not use a dimmer. Needs the full voltage.........
carambola 08-04-2009 08:14 PM
if you use a dimmer on a motor, the motor will hum
but i'm not sure of the tune
