Detached Member
I want to move a HB ceiling fan from my bedroom to my patio (it's rated for wet conditions). My question is that the current electrical source is on a heavy duty dimmer for some other lights on the patio. I can use incandescent or dimmable CFLs for the lights, but what about the fan? It's a pull chain job with three speeds and off. Will the use of the dimmer eff up the motor, or not work at all. I can try and run another 110v line, but it would be a pain. Again, because of other dimmable lights on the circuit, I don't want to use a two switch HB two switch dedicated wall switch if I don't have to. Any thoughts? Thanks
Hugh |
I had the same set up in the park house when we moved in (fan on a dimmer switch, fan would not work) I wired the fan directly and the lights are on the dimmer.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Detached Member
Thanks, that's kind of what I thought.
Hugh |
Recently installed one that has a remote control for the fan. Instructions were clear to not use a dimmer. Needs the full voltage.........
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles Last edited by LakeCleElum; 08-04-2009 at 08:55 PM.. |
if you use a dimmer on a motor, the motor will hum
but i'm not sure of the tune
Chris the more i learn, the less i know |
