mudman's Avatar
Non Porsche engine advice needed: Jeep 4.0
I'm refreshing the engine in my Jeep and adding a few mods. Among other goodies a Mopar Performance high pressure/volume oil is going in. Unfortunately there is interference between the pump and crank. I've removed material from the pump and the crank spins freely now, but how much clearance is enough?
What do you guys think? .05"? .125"? ???
'73 911 and other cool stuff
Old 09-08-2009, 03:40 PM
Banned
m21sniper's Avatar
I've never heard of a 4.0 oil pump going before. I would honestly just use an OEM.
Old 09-08-2009, 03:52 PM
mudman's Avatar
The original part can't be reused and the Mopar unit was a gift from my brother, so that is what I'm using.
Old 09-08-2009, 04:17 PM
lm6y's Avatar
What does it say in the Mopar Performance catalog? I've never seen them fail to note if something needs clearanced, and how much. I'm with Sniper, I've NEVER seen a 4.0 pump die. It's usually the bearing clearances opening up that drops the oil pressure. But what do I know, one of mine has 300K on the clock, and the "new" one only has 250K on the clock. Neither have ever been apart. Both do sound like Isuszu diesels though.
Old 09-08-2009, 05:36 PM
Oh Haha's Avatar
I did some searching on "The Web" but found nothing to help you.
You may want to PM Pelican SCHNELE. He works at a Chrylser.JEEP dealership. He may be able to find out more.
Pacific Blue
Wayne
Old 09-08-2009, 07:06 PM
Friend of Warren
Having owned at least 6 Jeeps with the 4.0 I can also attest the oil pump will be the last thing to go, but that is not the issue. What part of the pump are you removing the metal from? I would try to get as much clearance as you safely can without compromising the pump.
Kurt V
Old 09-08-2009, 07:16 PM
mudman's Avatar
The cast body of the pump is pretty thick, and I've removed about .07" of material to get good(?) clearance.
The only note from Mopar was about having to 're-work' the oil pan. I just put the hammer down...
Old 09-08-2009, 07:30 PM
Laneco's Avatar
*Note* I am not a Jeep expert and I did NOT sleep in a Motel 6 last night...
That said, I really think that you need a bit more clearance for safety. It would seem to me that with a fairly large displacement straight six, there could be more of a whipping action with the crank, a little bit of flex, and the inevitable expansion of heated parts. Plus, let's be honest, Jeep manufacturing tolerances are not the same as Porsche's - LOL!
The .125 in the afore mentioned robust casting certainly seems safer to me. I'd be much happier to accept a failed oil pump than a crank-pump collision...
angela
Hello
Old 09-09-2009, 06:25 AM
Friend of Warren
Angela explains the need for clearance much more eloquently then I did!
Kurt V
Old 09-09-2009, 06:28 AM
mudman's Avatar
Well, I've got .05 clearance in all but one spot. I'm going at it again and should be able to get .10" by reworking one spot. The leading/corner edge of the counterweight is closest right now at .012".
Thanks for your help! But I'm still hoping somebody will have a number...
Old 09-09-2009, 07:33 AM
mudman's Avatar
Just got off the phone with a Mopar Tech guy, he said .030" is safe, if it causes interference with that clearance I've got other troubles...
I'm still going for .100"
Old 09-09-2009, 07:51 AM
Oh Haha's Avatar
Sounds like you are pretty close.
I was at the Chrysler Tech Center today but I couldn't find an engineer that would answer the question.
Pacific Blue
Wayne
Old 09-09-2009, 01:33 PM
Over 40 victim of fate
stogie25's Avatar
When I built my 4.7L stroker out of a 4.0L for my Jeep, I got a high volume oil pump with the kit that had the dual roller timing chain, and some other goodies. Western Engine did the final assembly due to the warantee vs. cost. Throughout that project I got valuable advice from Hesco, and of course Terry from Western Engine.
http://www.hesco.us/customergallery.asp?action=form&formID=1725&recordID=90227
http://www.westernenginesupply.com/
There is also a lot of good information on:
http://www.jeepforum.com/forum/index.php
http://www.jeepstrokers.com/forum/
Good luck...Jeep wave,
black 1988 Porsche 944 (30 years old and getting younger every day)
black 1997 Jeep Wrangler (very modified)
I didn't know cars came in other colors
Semper Fi
Old 09-09-2009, 02:46 PM
Laneco's Avatar
4.7 liters? Dangggg..... I would really love to sling some mud with that baby! Torque is FUN!!!!
angela
Hello
Old 09-09-2009, 03:13 PM
stogie25's Avatar
Torque is fun. The Jeep and I have been driving over things for 13 years now.
Semper Fi
Old 09-09-2009, 03:26 PM
