Can anyone tell me what happened to this tire?
Rick
88 Cab
Old 10-31-2009, 09:42 AM
Registered Abuser
MT930's Avatar
Looks like retread cap separation on a truck tire.
Hopefully a rear tire!
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 10-31-2009, 09:49 AM
The Unsettler
stomachmonkey's Avatar
Yup
"I want my two dollars"
"Brandon Won"
Old 10-31-2009, 09:53 AM
Laneco's Avatar
It is a little hard to tell from the picture, but I believe what I see there is actually a failure of the tread to sidewall ply. As if the tire were run with a significant alignment issue and wore the edge severely, or were run nearly flat.
I'm going with ply failure (for one of the two above reasons) as it looks like the edges of the opening have torn polyester ply(s) visible.
If it is a recap, it's more than just tread seperation. It's an actual failure of the original tire carcass. Meaning not only is it bad, it is not suitable for another recap either. It's a "shredder" tire.
Obviously replace this one, check the dates on the other tires as well. Dates older than 5 years become suspect pretty fast. Look for the four digit code on the sidewall. The first two digits are the week of manufacture, the second two are the year of manufacture. If I recall correctly, this marking was mandatory after 2000 and some makers did it voluntarily prior to that date.
angela
Hello
Old 10-31-2009, 09:59 AM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
I see the words Radial T/A, isn't that the group of tires that had a recall for just that type of failure a bunch of years ago?
Old 10-31-2009, 10:00 AM
Banned
m21sniper's Avatar
Looks like a re-tread.
Old 10-31-2009, 10:03 AM
It is not a retread it is a 14" wheel on an Subaru Imprezza. The car is 600 miles away so all I have seen is the picture also.
How low an inflation would cause this? The tire did have a nail in it, that is why it was brought in?
Do you think a road hazard warranty would cover this? It is on an AWD drive car so I am also looking for the different circumference specs for Subaru.
Rick
88 Cab
Old 10-31-2009, 10:32 AM
sort of looks like it was run flat/underinflated and driven on.
Old 10-31-2009, 10:45 AM
Unregistered
sammyg2's Avatar
BF goodrich radial T/A tire, not much chance of getting one of those re-treaded.
I say either too much toe in causing it to scrub around the edge, or the fender edge cut into it. Severe under inflation might do it too.
I assume that's a front tire, right? Howz the other front?
Old 10-31-2009, 11:28 AM
notfarnow's Avatar
+1
My guess is something cut into it. I wonder if there's tire "dust" all around the inner fender. I had a the front muffler changed on a Renault, and they had the pipe clamp turned to the bolt end was pointed towards the tire. Worked fine for ages until I went to pull a REALLY sharp u-turn and the clamp cut into the tire.
'03 Carrera 4s
+ a whole bunch of boats
Old 10-31-2009, 11:57 AM
Originally Posted by notfarnow View Post
+1
Yeah, a cut from rubbing. Running on an severely underinflated tire can cause similar symptoms including a groove worn in the sidewall, but there would be more rubbing on the sidewall itself. It's hard to say since the visible rubbing in the picture could have been post blow out.
What's the other side of the tire look like?
Old 10-31-2009, 12:02 PM
The other tires have tread wear just like the one shown.
I'm leaning toward under inflation but the tire store didn't mention it.
Rick
88 Cab
Old 10-31-2009, 12:09 PM
Rick;
I seem to remember something about the steel belts (if they are steel) getting moisture as the tire rubber cracked with age, and rusting, causing the tread sep like that. How old are they? Maybe some kind of NHTSA search could come up with recall if there was one. You'd need the info from the sidewall. And a good tire guy/shop would gladly do the research knowing he was gonna sell you some new ones.
Old 10-31-2009, 12:23 PM
Banned
it got too hot.
Old 10-31-2009, 12:47 PM
Bill is Dead.
cashflyer's Avatar
We are looking at the inside edge, so it is not a fender cut-down.
I would vote for being run severely underinflated, but it does not show any usual sidewall scuffing that is associated with underinflation and wallowing.
It does look like the inside shoulder is worn away on either side of the groove, possibly indicating a severe misalignment problem such as improper toe. Once the wear got down to the cap belting, it could have allowed a belt separation along the seam.
Still, the groove is so long and even that I'm inclined to believe something cut into it. I'm not familiar with an Impreza suspension setup; is it possible it was rubbing on a suspension component? Is it the correct size rim for the car?
Old 10-31-2009, 01:21 PM
least common denominator
scottmandue's Avatar
angela
I love it when you talk dirty.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 10-31-2009, 01:42 PM
Sultan of Sawzall
rouxroux's Avatar
By the scalloping close to the tread, it appears as if this one was run quite a ways underinflated.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 10-31-2009, 02:22 PM
MRM MRM is offline
I agree with sever underinflation. What probably happened was the nail hole caused it to deflate without the driver noticing for a long time, causing the secondary damage shown in the picture.
MRM 1994 Carrera
Old 10-31-2009, 04:00 PM
RETIRED
Joe Bob's Avatar
Something cut it it....likely the suspension settings are at fault.
Old 10-31-2009, 05:10 PM
Laneco's Avatar
Yeah when chicks talk tires it just puts a little wiggle in your walk now doesn't it!
Oh, and road hazard will cover this when those monkeys from oz fly out of sniper's nether regions (or he moves to california).
angela
Hello
Old 10-31-2009, 07:56 PM
