Detached Member
On my 08 Camry hybrid, I have the push start. You hold the push start button down for 3 seconds to kill the engine, you lose power steering, brakes, I don't know cause I tried it stopped in my driveway. Only way I know about this is from what I read re: this accident.
Hugh |
Yes, you lose power steering and power brakes. But, you still have steering and brakes. It's not like those systems go completely dead. You can still stop/steer a car without the engine running...even with old American land-yachts. I was able to drive/stop my old F350 when it threw a belt. No PS, no PB, no Vacuum. It was like trying to steer through molasses, but I was able to coast to the side of the road and turn into a parking lot.
Turn it off or put it in neutral make sense but how about this obvious solution.
What would happen if the driver just slammed on the brakes and engaged the emergency brake? I have no clue if that would stop the car but I would think it would keep the vehicle from going 120mph. |
Slackerous Maximus
I know I I'm not supposed to laugh at that....but.....
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
The hydraulic systems that were popular in Audi's are supposed to be good for 5.
Rick 88 Cab |
To clarify a bit. The car was a loner and a different model than his own car. The push button ignition requires a continual three second hold down to shut off the engine. Given the circumstances, I can see how an experienced CHP officer would not be able to turn off the engine, in this case.
Does anyone know how the steering lock is engaged in a car that does not use/need a key inserted into the switch? My understanding is these cars can be started with the button with the "smart key" in proximity of the ignition, not necessarily inserted.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 11-05-2009 at 11:47 AM.. |
Why would the brakes not stop the car? Even at full throttle the brakes will stop any car. Even an Audi.
Senior Member
Stupid design, and Toyota deserves to get taken to the cleaners over it. There is no key to remove and try holding a button in for 3 seconds while the car is out of control.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Fox News is not a reliable news source to begin with......sorry I had to say it
Run smooth, run fast
There was a segment on this a coupla nights ago on Nightline. I thought they were going to end it without telling people what to do if it happened to them, but they squeezed it in at the last minute.
They consulted a test driver from (I think) Consumer Reports and he demonstrated putting a car in neutral, braking to a stop, then turning it off. It's amazing to me that people are calling 9-1-1... that is the last thing I would be using precious seconds for if this happened to me. If I hadn't seen that Nightline segment, I think my first reaction would be to try brakes, then if that didn't work, I'd yank it down into low gear... you're sure never gonna hit 120 in low. If I still couldn't get it stopped and hadn't thought about neutral, I think I'd be ramming it into reverse or park. If there was a lockout, I'd be looking for stuff to sideswipe to scrub off speed until I found a soft target to use for a final stop.
- John "We had a band powerful enough to turn goat piss into gasoline." |
I do know this, that you'd be surprised at how hard a car is to steer when suddenly you lose power steering. It happened to me once when my engine cut and I could hardly steer to the side of the road, was really quiet shocking how hard it was.
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
another round please
Getting old is not for wimps. |
My '02 Tundra: you must not only turn the key, but then push it in and turn it further to remove the key and engage the steering lock. While in drive, the key cannot be turned far enough to engage the steering lock. No power assist, but a sacrifice I'd make, kill the engine. I don't know the workings of the specific Toyota in question, but it seems that the company has thought through the possibility that the driver might need to kill the engine and not lock the steering wheel, and designed the ignition to make this easily possible in an emergency situation.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
I think the Nightline segment said Toyota began putting these drive-by-wire throttle systems in their cars in '04 or '05. Remember, it's Lexus, too.
Any new car, especially something like a Toyota sedan... can bounce off the rev limiter hours most likely. I don't know why people just don't throw it in nuetral. Or hell... if you're that out-of-time... throw the f-er in park. Sure it's going to probably makes expensive noises and lock up tires but who cares... especially if you are doing 120 and out of control..
Another thing that I'm thinking on ... Just from my time in race engineering ... and calculations involving brake systems- the brakes of a modern car should be able to dissipate more energy than what is being generated by the engine. In most cases, more than twice the energy. For instance... A Formula Atlantic I worked with could accelerate at a sustained 1.1 G's. However it could brake at nearly 2.5 G's. Even an anemic brake system is able to dissipate 2 or even 300 horsepower of heat, and it should be able to do this long enough to stop a car. I'm sure a new lexus has a relatively large brake system, and even if the engine was making peak power, jamming on the brakes should be able to pull the car down to a safe speed if not stop it, long enough to fix the problem. The only variable here that I do not know about is ABS. I have never worked with ABS systems and how they would respond to this, maybe they would prevent the brakes from being able to kill the engine... I don't know. In my mind though it shouldn't.
M |
Banned
there is no key to turn
once the brakes overheat the brake fluid boils and you got no brakes report on this crash inc pictures http://www.safetyresearch.net/Library/NHTSA_Santee_Inspect.pdf Last edited by nota; 11-06-2009 at 09:25 AM.. |
My keyed '00 Celica has the ACC position between off and on. If you turn the car to the ACC position the engine will stop but you can still turn the wheel around all you want. It won't lock until you're one more position over in 'off.'
Dunno how much that counts for since it's got a key, but it is a Toyota. edit: and one with a throttle cable. And the only problem I've had is the cast nut on the belt tensioner you crank on to release tension on the belt sheared off. Makes installing a new belt a little more exciting and creative!
'87 924S (Sold) Last edited by Scuba Steve; 11-06-2009 at 11:42 AM.. |
I dont think putting the car into Park or Reverse is possible while driving...at least thats what the Mythbusters found.
If all else failed, I would start ramming the center divider at an angle to slow the car down and hopefully break something so the car would stop. Grind it to a stop.
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
Unoffended by naked girls
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
