Nothing is worse than those 4x4 tiles the builders use. Lots of seams and most do not use an epoxy grout. Also, installation is everything on these produts. this is not a place to get a second rate installer.
Stone products like granite or man made quartz are harder materials compare to Corian or similar products. So the wear rate should be better or last longer. Corian should last a loooong time. Like anything else, you have to take care of it but there isn't any care but a clean damp rag should do the job. The best way to clean grout is steam and a stiff brush. |
