question for electrical gurus on undercounter lighting
I'm installing some GE LED undercounter lights. The lights and wires have tags that read, "not for current interruption"
I have a switched outlet that the old undercounter lights were plugged into so I can turn them on and off with a wall switch. What's the concern with having the power switched off at the wall? |
Not for current interruption means that it should not be disconnected under load. For example by directly unplugging or by an in-line switch.
Typically there is something between the "not for current interruption" load and the power source which ensures graceful power down. |
So what could go wrong if I use a wall switch?
You could miswire it and burn your house down
Using the setup the way you described is a correct way to switch them. |
So running the feed into the switch and then joining the switch to the lights inside a junction box provides a safety link? How so?
A switch is designed to make and break electrical contact, those plug in connectors are not.
So a wall switch shouldn't cause shorter LED life or anything like that?
David,
The switch will not cause a shorter life of your LED lights. Just refrain from "unplugging" them while powered on. |
I'm curious which ones you are using?
I'd like to put in LEDs but they are spendy. |
They're about $65 each from Home Depot. Even with just 4 LEDs each, they're about as bright as fluorescents.
http://forums.pelicanparts.com/uploa...1260481897.jpg |
Nice.
IKEA has really cheap options for under-the-counter lights. But not LED. |
I wasn't going for energy savings when I tried these, but it is nice that they're only 5 watts.
Let us know how they look when you finish. How warm is the light? |
| All times are GMT -8. The time now is 12:11 AM. |
