David's Avatar
question for electrical gurus on undercounter lighting
I'm installing some GE LED undercounter lights. The lights and wires have tags that read, "not for current interruption"
I have a switched outlet that the old undercounter lights were plugged into so I can turn them on and off with a wall switch. What's the concern with having the power switched off at the wall?
Old 12-09-2009, 04:17 PM
Whoopsies I was banned!!!
Esel Mann's Avatar
Not for current interruption means that it should not be disconnected under load. For example by directly unplugging or by an in-line switch.
Typically there is something between the "not for current interruption" load and the power source which ensures graceful power down.
Old 12-09-2009, 04:55 PM
David's Avatar
So what could go wrong if I use a wall switch?
Old 12-09-2009, 05:03 PM
Used & Abused
You could miswire it and burn your house down
Using the setup the way you described is a correct way to switch them.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 12-09-2009, 05:44 PM
JavaBrewer's Avatar
If that's the case then I would suggest a different light setup. My home came with flourescent light fixtures under the cabinets. They were hard wired to a wall switch. I ditched the lights and ran the live wire up between the cabinet bases (3/8" gap) and installed a junction box. From there I ran multiple halogen puck lights above, inside, and under my kitchen cabinets. Looks great and the light bulbs last ~ 12 months a pop.
Old 12-09-2009, 06:03 PM
I see you
flatbutt's Avatar
So running the feed into the switch and then joining the switch to the lights inside a junction box provides a safety link? How so?
Old 12-09-2009, 06:41 PM
Used & Abused
A switch is designed to make and break electrical contact, those plug in connectors are not.
Old 12-09-2009, 07:19 PM
David's Avatar
So a wall switch shouldn't cause shorter LED life or anything like that?
Old 12-10-2009, 11:05 AM
DByers's Avatar
David,
The switch will not cause a shorter life of your LED lights. Just refrain from "unplugging" them while powered on.
Dan Byers
Old 12-10-2009, 11:27 AM
AutoBahned
RWebb's Avatar
I'm curious which ones you are using?
I'd like to put in LEDs but they are spendy.
Old 12-10-2009, 12:33 PM
David's Avatar
They're about $65 each from Home Depot. Even with just 4 LEDs each, they're about as bright as fluorescents.
Old 12-10-2009, 02:14 PM
Nice.
IKEA has really cheap options for under-the-counter lights. But not LED.
Old 12-10-2009, 02:32 PM
David's Avatar
I wasn't going for energy savings when I tried these, but it is nice that they're only 5 watts.
Old 12-10-2009, 04:19 PM
fuelie600's Avatar
Been waiting for the prices on these to come down some. Might have to just go ahead and buy. I have 12 halogen puck lights now and I hate them! They are very hot. They bottom shelf of the cabinets gets very hot.
Let us know how they look when you finish. How warm is the light?
Evan
1987 sun roof coupe
Old 12-11-2009, 06:54 AM
