Wandered off somewhere...
Drdogface's Avatar
Strange Smoke alarm problem ??
Hopefully someone can shed some light on this and help us resolve.
We have a fairly larger home..at least for us...and maybe 8 smoke detectors installed in various rooms. They are connected to house wiring and have back up batteries. Our problem started with just one in a hall way which seems to beep all the time...as if the battery is out. We changed the battery...no help. I called the mfg. Cust. Scvs and they said to a different kind/works a different way and sent me one. This is no help either. Now a few of them beep but mostly when the house cold...like at night when we turn the thermostat down. They beep in the early AM until we heat up the house. It's driving us nuts. All the batt's are OK...
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 01-16-2010, 12:21 PM
Dueller's Avatar
Had similar problem with hardwired alarms...did the same thing with new batteries. Electrician told us to use compressed air can to blow any dust out, change batteries and hold test/reset button down for 20 seconds, release and test again. Something about clearing fault code. Seemed to have worked for ours. Also...do you have CO detectors? Did the same thing with those as well. All quiet on the southeastern front now.
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 01-16-2010, 12:48 PM
Drdogface's Avatar
Thanks Jim...I'll try it
Mark...
Porsche Boxster S
Old 01-16-2010, 02:01 PM
+1 on the blow out,
Dust and stuff build up in units and cause the beeping, January is a good time to replace the batteries and clean them.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 01-16-2010, 03:43 PM
lowyder993s's Avatar
Ours go off in the summer when the humidity rises(not beep...I mean GO OFF). Usually 4-5 a.m. I'll try Jim's fix...hopefully it works out
Jim
76 911s 3.6l Track Car
05 Ferrari F-430
"If its worth doing...it's worth doing to excess"
Old 01-16-2010, 03:47 PM
williecoyote's Avatar
+1 to blowing dust out of the sensors.
A good time to change batteries is spring and fall, when you change your clocks for daylight savings time.
Will
85 carrera
Old 01-16-2010, 05:07 PM
jeffgrant's Avatar
We had the same problem in a past office.
Turned out that high-humidity, when it got cold, clogged the sensors and raised a fault.
Blowing them out reduced the ability for condensation to form on the sensor. Raising the low-temp setpoint solved the problem, but we just opted to occasionally blow-out/reset the sensors when they would go off.
PITA, but what can you do?
Old 01-16-2010, 05:28 PM
Canadian Member
911Rob's Avatar
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 01-16-2010, 09:29 PM
