faster than I once was...
btw:
the rep from Drillco taught me: what "we" call drill bits are actually drills and what "we" call drills are actually drill motors I haven't found anyone else who talks this way.... but 1/4" isn't 0.250 to me either...
~Dave |
We have some Makita Cobalt bits that are excellent... I think they came off ebay... Find a good brand and pick them up cheap....
Checked your profile, but didn't see where you are. Travers Tool is a company I like for drill bits, etc. They have a place in Duncan, SC which means my order is on my porch next day with UPS ground shipping. They have selection from cheap to quality bits. They have a website.
Seems like you've got good recommendations as far as USA bits and the Cobalt bits hold up better in deeper holes. If you are using a drill motor, mechanics lenght, which is shorter than the standard jobbers length would be good. A split point is better in that it starts easier.
drew1 wife has 924 turbo |
Go to your local hardware store and buy the American made bits. If you are using a drill press, it will be a piece of cake. The last time I drill a bunch of 1/4" steel for a stair case was done with my local hardware store American make bits. I just keep spraying it with WD40. I had to drill something like 50-60 holes. I was only just able to kill 2 drill bits. Went to the grinder to sharpen it right up. Go slow and keep the bit cool. Once you see lots of smoke, back off and spray or put a little ATF on and around the little hole. Are you drilling tool steel? Try to get a bit that's been grind for steel. If you are using a drill press, it shouldn't matter all that much but... How many holes?
one more thing:
the 135 degree split points start quicker and straighter than the 118 degree - you usually don't need a pilot hole - a center punch still helps for precision unless you're using a press.
~Dave |
Senior Member
Absolutely the last place in the world I would go for drill bits is HF. The quality of their steel is the worst I have seen in years. Same for cutting blades for a sawsall.
If you want to drill, get a good bit.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
