lm6y's Avatar
Guitar wiring
I'm rewiring an old Jazz Bass copy I have. Right now it has a single volume, a single tone, and a 3 way toggle switch. It has a "P" EMG split single coil in the neck position, and a "J" in the bridge position. The switch is shot, and the pots have dropouts, and scratchy spots.
I want to change it to Two volumes, and One tone, and do away with the switch. The schematic from EMG says to use (3) 500k pots, and a .05 mfd cap.
The questions I have, is whether I should use linear taper, or audio taper pots. Or wire wound, or non wire wound pots.
This is all going into a cheap, late 80's J.B. Player neck - through Jazz Bass copy. The frets have been ripped out of it, and I'm thinking of switching to flatwound strings. I know it will never sound amazing, but the damned thing actually plays really well.
What say the Brain Trust?
Brent
Early85 944
LM6Y Paint Code
Old 01-31-2010, 07:46 AM
Band.
IMO:
Yes, use "Audio Taper" pots, you might consider using a 1Meg pot for the Tone.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-31-2010, 08:03 AM
lm6y's Avatar
Why 1m for the tone? Not doubting you, but I want to learn this stuff.
Brent
Early85 944
LM6Y Paint Code
Old 01-31-2010, 09:40 AM
Band.
In short the higher value pot will provide a greater 'range' of the tone pot, mostly on the bright end of things. If you're already fretless and thinking of flat-wound you might want to have a little more range of that tone knob in case you find the whole rig a little dark.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 01-31-2010, 10:02 AM
lm6y's Avatar
Thanks! You just can't buy info like that.
Brent
Early85 944
LM6Y Paint Code
Old 01-31-2010, 10:15 AM
fritzgator's Avatar
Actually, if i'm reading right, you have an EMG PJ set, which will want to see the 25K audio taper pots to operate properly. Pm me your email and i'll send you a pdf schematic for 2 vol 1 tone. it will be diagram 2. good luck.
Gator
99 996 c4
Old 01-31-2010, 12:31 PM
lm6y's Avatar
Gator, this is the schematic I'm working with. the pickups are just el cheapo EMG selects, and this is the EMG schematic for the PJ set.
Brent
Early85 944
LM6Y Paint Code
Old 01-31-2010, 02:17 PM
GuitarElectronics.com GuitarElectronics.com Home Page
A massiv resorce for guitar wiring!
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 01-31-2010, 02:19 PM
lm6y's Avatar
Thanks!
Brent
Early85 944
LM6Y Paint Code
Old 02-01-2010, 05:42 AM
fritzgator's Avatar
Ah, i see, those are passive, so i'd go with the 250k audio taper's across the board. 500's will make it brighter,but brighter bass just doesn't sit well with me. Diagram's good. Send it!
Gator
99 996 c4
Old 02-01-2010, 09:57 AM
