AR guys, why is my M4 so inaccurate?
I tried to sight in my M4 with Millett Zoom Dot scope today at 50 and then 100 yrds. There was a slight breeze, but nothing much. Shooting from a bench, with my foregrip resting on a carpeted wood block, my red dot at the smallest it could be and still able to see it, I could not hit a quarter-size orange decal on the paper plates I used for targets. I got pretty close at 50 yds., but was all over the map at 100 yrd. WTF is wrong with me? I am normally a very good shot with handguns and my .30-06. Now I've built another M4 and am trying to figure out what kind of sights to put on it. I need to figure out if my highly modded Bushmaster is just inaccurate or if I suck so bad that I need fancy optics to compensate. What can make such a rifle so inconsistent? Seems there's not much adjustment other than the nut behind the wheel.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
A Man of Wealth and Taste
U need someone new behind the trigger
Copyright "Some Observer" |
what bullet weight?
poof! gone |
Banned
Remember Rick, it is a carbine- hitting a quarter sized target at 50M is very good accuracy for a carbine! You might get even better results with other ammo. Try different types. Rick, the #1 thing that makes a rifle inconsistent is the shooter....or poorly stabilized rounds. What's your twist rate, what were you shooting? |
Sniper, I think my Bushmaster is the same one you have, XM15-E2S. Is that 1:9 twist? Though the barrel and lower receiver are about the only stock parts left on it. I was using the cheapo steel case Silver Bear today, I think in 55 gr. My scope's reticle is really a red dot that's 10 MOA at its largest and one at lowest. Of course, I tried to make it as small as I could bear, though putting a red dot on an orange decal in bright sunlight was not real easy for me. Next time I'll be using black targets.
I want one of my M4's to be for close work, sort of SHTF home defense and the other for reach out and touch someone work, when I run out of .30-06 ammo - muhahahaha. Kinda thinking about putting this Millett scope on my new one and keeping my Bushmaster for close-quarters stuff. I have a killer 700 lumens taclight/grip with a laser built into it. But I like carrying it for a flashlight. Just can't decide what to do here.
B58/732
This may sound stupid...but are your scope rings tightened down?
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Parrothead member
Rick, is that a new sight? I know it always takes me a long time to get used to new optics. maybe you just need to get used to it?
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I've had this scope for two years and figure I have close to 1000 rounds with it. I'm pretty sure it's snugged down. I had Noah's M4 Superlight a few years ago, nothing more than iron sights and it was super accurate. I shot everything standing up with nothing to rest against and was still killing ultra thin steel fence posts way far away. I think it's something with my rifle.
Somewhere in the Midwest
Did you damage the barrel crown? A nick or something to affect the exit trajectory?
When you say you were all over the place, was it random dispersion of POI? I've never shot the Russian stuff, but I hear they aren't great for accuracy. You might inspect the rifle barrel (and scope) then try a different type of ammo. Last edited by MotoSook; 02-07-2010 at 08:48 PM.. |
When I am doing range safety work at the South Bay Rod and Gun Club range in Delzura (near Chula Vista) I see a lot of M4s and/or AR15s that have issues. They are usually caused by the following, not in any particular order: cheap or poor quality ammo, shooting 5.56 in a rifle chambered for .223 (works the other way), bullets are wrong for the twist rate, bullets are wrong weight or profile, trigger is not setup well or the trigger pull is causing the gun to move when squeezing and finally the head spacing is off for the chamber. I would address these in order of ease, get a few match quality bullets to see what happens, try iron/peep sites since a good shooter can hit to 300 yds easily with them. Chack the barrel and make sure the ammo matches what you have for the barrel. Finally check the trigger and make sure it is smooth, even with no creep and breaks clean.
If you are holding the dot on target at 50yds then you will have to adjust for 100 and that can be a problem. Make sure that the site has been mounted correctly so if you move the dot vertical then it goes up and not at an angle. I bought a Wheeler scope mount kit and it was well worth the price and on my red dot I use the magnetic levels to make sure that all is well. I also have a bore laser sighter and use it at night before going to shoot to make sure that the scope/red dot is lined up okay with the adjustments about in the middle at 50 yds. If they are already to one side then the mounts are not correct or there is a problem. Good luck with it. |
any slop between the upper and lower? Maybe you need an accuwedge. Also, how secure is your butt stock? Maybe your carbine just doesn't like that brand of ammo...
Senior Member
Was just waiting for this! Coming from the Tabdula the Great, its even better!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Banned
The wide dispersion at longer range does seem problematic though- what sized groups were you shooting at 100m? Was it under 2"? I would try again with XM193 and a few other brands of ammo- i suspect the problem was just poorly QC controlled ammo. Last edited by m21sniper; 02-08-2010 at 06:33 AM.. |
Of course, I adjusted W & E when moving to 100 yds. I started at 50 because I couldn't remember if I had shot that rifle since I'd last removed the scope. When that was pretty close, I moved to 100. My groups were probably in the 4-5" range at 100 yds. I had a spotting scope to check the targets after each shot. It was pretty embarrassing. Who are these guys who can shoot good groups at 300 yds. with iron sights? I want what they're having.
Banned
To qualify in the Army you have to be able to hit pop up silhouette targets at 300m with an M-16 or M-4.
Before i got totally wigged out, i would try again at 100m with some quality ammunition, preferably a couple different brands. With XM-193 or M855 you should be able to shoot 2.5" or less at 100m with a carbine. When you find "the" ammo for your specific carbine you might get that well under 2" at 100m. It really makes no sense that your groups quadrupled in size from 50 to 100 meters. Also, if you're having problems next time, let someone else try- see if they can do better. If they do a lot better, it's time to start re-checking yourself for poor fundamentals(it can happen to anyone over time). PS: AR's should be zeroed at 25 meters. Last edited by m21sniper; 02-08-2010 at 06:45 AM.. |
Cars & Coffee Killer
Was their a loose nut behind the trigger? I'd start with the castle nut.
![]() I can't shoot distances without optics either. Anything past 25 yards and I'm lucky to hit the paper with iron sights.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Hell, if I had known that, I could have saved myself some ammo and aggravation. I can easily hit targets at 100 yds. I just like to be able put them all in the same hole without it getting too big, as I can do with handguns.
Banned
When you zero your AR at 25 meters with XM193 you have a MPBR of 330 meters (in a 20" M16A2, less for a carbine). IOW, holding on the center of the target, all your rounds should be in an approx. 12" circle out to about 330 meters.
All 5.56mm combat rifles should always be zeroed at 25m. MPBR explained: http://www.rmvh.com/MPBR.htm Just find the ammo that shoots the smallest group at 25m, zero it at that range, and you're good to go. Last edited by m21sniper; 02-08-2010 at 06:56 AM.. |
Ok, I need to do some ammo shopping and then figure out what to put on my new build, take them both to the range and get it all sorted out.
Banned
Rick, you might also seriously consider going with a drop in match grade trigger. That makes a bigger difference in real world accuracy at the ranges you're going to be shooting than any other change to the weapon you can make.
Timney drop in trigger ![]() McCormick single stage "tactical match" grade trigger. (This is the one i have) People always buy optics over a trigger, but IMO that is a novice mistake. A smooth, light, consistent trigger is the single biggest upgrade you can make on any spoon. Last edited by m21sniper; 02-08-2010 at 07:36 AM.. |
