-   -   3 phase hoist to single phase, can it be done? (http://forums.pelicanparts.com/off-topic-discussions/529988-3-phase-hoist-single-phase-can-done.html)
vonsmog 03-08-2010 05:36 AM
I picked up this hoist for next to nothing on CL. Would like to convert it to single phase if I could. If not i will post it on Ebay and make a profit. I do have a use for it, but I don't want to spend a ton of money for a phase converter, would just like to make it work with single phase. Anyone know if its doable?
Thanks, Vonhttp://forums.pelicanparts.com/uploa...1268055393.jpg
red-beard 03-08-2010 05:43 AM
Change the motor?
cmccuist 03-08-2010 06:02 AM
What horsepower is the motor? The best device out there for converting from single phase 220V to 3 phase is the Variable Frequency Drive! I have one for my mill and I can adjust the spindle speed using the VFD.
A VFD for a 2 hp motor goes for about $160. Very easy to install.
Tim Hancock 03-08-2010 07:00 AM
I have one of these to run my 3 phase mlling machine off of my 220 single phase shop wiring..... Simple to wire and works perfectly.
Mine is the 1-3 hp model like shown in this link, but they offer one size smaller for up to 1 hp motors.
Here it is on the Phoenix website, but they sell them on ebay also for a bit cheaper with free shipping which is how I bought mine a couple years ago.
1 HP to 3 HP Static Phase Converter
If your motor is 1hp or under, you should probably get this one for $59 on ebay w/ free shipping.
Phase Converter 1/ 4HP to 1 HP STATIC new - eBay (item 310204313077 end time Apr-01-10 17:39:51 PDT)
Rotary phase converters or VFD's work great also, but for a simple motor with no complex electronics or computers, the static units that I linked to work just fine. IOW, the static converter works fine for my simple mill, but would probably not work properly on my CNC mill. When I get around to getting it going, I will probably have to get a rotary phase converter.
rick-l 03-08-2010 07:17 AM
You can also use a three phase motor with no load as a rotary transformer. An old junk 3-phase with a higher horsepower rating. You have to pull start it before you use it.
legion 03-08-2010 08:08 AM
Sounds like a perfect application for a retro encabulator to me.
vonsmog 03-08-2010 10:43 AM
Thanks for the link for the phase converters! Since the motor is only 1/2 HP I got the one for $59.00 off of ebay! Just hope it works now! Thanks again, Von
T77911S 03-10-2010 05:20 AM
cant you add a capacitor to one of the legs of the 220 for the 3rd phase?
BK911 03-10-2010 06:23 AM
Ahh, rockwell industries.
YouTube - rockwell automations
Tim Hancock 03-10-2010 08:54 AM
That is basically what the static phase converter does.
