-   -   My laptop keeps freezing. Help. (http://forums.pelicanparts.com/off-topic-discussions/532592-my-laptop-keeps-freezing-help.html)
Rick Lee 03-22-2010 02:02 PM
I have a four yr. old Dell Latitude D610 that sometimes will boot up, but eventually freezes and can only be unfrozen by rebooting. How do I even start fixing this?
tangerine911S 03-22-2010 02:08 PM
Try reimaging your hard drive and reinstalling your operating system. You may have to back up all that you don't want to lose. Or at least insert the OS cd and see if you can "fix" the OS.
imcarthur 03-22-2010 03:03 PM
Does it have a wifi card? My Vaio worked absolutely perfectly, except when it didn't. In most hotels/locales it worked like a charm, but I ran across 2 hotels when it would boot, auto start wifi & blue screen. Updating the Intel wifi drivers solved it.
Ian
Rick Lee 03-22-2010 03:06 PM
I don't believe I have an OS cd for this one anymore. And I probably couldn't keep it running long enough to back up everything anyway. Yes, it has a wifi card, which reminds me that, when it's running fine, it disconnects from the Internet a few times per hour too.
sailchef 03-22-2010 03:44 PM
Add more memory?
island911 03-22-2010 04:02 PM
I would boot into 'safe mode' (F8 key on boot)...see how that works. Your hard-drive could be going south. ...hope you have things backed up.
http://support.microsoft.com/kb/315222
Rick Lee 03-22-2010 05:07 PM
No, I don't have things backed up. I have an external drive for doing so, but don't know that I can keep this machine running long enough to complete the backup. Can I back things up in safe mode? I have it up and running in safe mode now, but don't know what to do next.
imcarthur 03-22-2010 05:11 PM
Is the external visible? If yes, then back up your data files, favorites, email etc.
But if it runs & doesn't crash with normal drive access in safe mode, then it is a driver issue & probably not a drive or memory.
Ian
Rick Lee 03-22-2010 05:14 PM
What do you mean visible? It's completely separate piece of hardware I have in a storage bin somewhere.
I'm doing a system restore in safe mode back to Jan. 1, which I think was before any of this started. I don't have anything on there since then that I can't live without. The system restore seems to be working fine. Sure would hate to lose some of the old porn on this one.
porsche4life 03-22-2010 05:23 PM
Paging slodave!
I'm about to backup a Dell for a friend. Got a virus...
Rick Lee 03-22-2010 05:36 PM
System restore didn't work. But it booted up fine. I guess I need to back things up soon and try another restore.
stomachmonkey 03-22-2010 05:54 PM
HD should be easy to get to. Should be under a panel. Yank it and get something lke this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3265860&CatId=3770
Sabrent USB 2.0 to IDE/SATA Cable for 2.5-Inch/ 3.5-Inch / 5.25-Inch Drive with Power Adapter at TigerDirect.com
plug it into another computer and pull your data.
imcarthur 03-22-2010 05:56 PM
When you plug it in, can you find it in Explorer? Look in My Computer>External Drive: ( ? : )
http://forums.pelicanparts.com/uploa...1269309291.jpg
Ian
Arizona_928 03-22-2010 06:01 PM
Try going to Dell and requesting a OS cd. My 1505 crashed hard, and dell overnighted me the cds. The only thing is I lost everything on it... but it runs like new. =D
Rick Lee 03-22-2010 07:16 PM
Dell ain't gonna help me. I sort of kept this laptop after a previous employer went belly up and locked the doors on folks. I found some guy on Craigslist to reformat it and reload Windows, which is probably pirated. No way anyone is gonna touch this machine.
stomachmonkey 03-22-2010 07:39 PM
Does it have the Windows sticker with the license key on the bottom?
Rick Lee 03-22-2010 07:40 PM
Yes
stomachmonkey 03-22-2010 07:43 PM
Originally Posted by Rick Lee (Post 5252171)
Yes
Then you have a valid license key.
Download a torrent of an OEM OS, load it and enter your key number.
Rick Lee 03-22-2010 07:47 PM
Locked again now and locked while rebooting in safe mode. No way can I keep this thing running long enough to download an OS and then run that. I'll be overjoyed if I can get it backed up. Might end up pulling the hard drive and handing it off to someone to copy for me.
Rick Lee 03-22-2010 08:16 PM
I tried a system restore back to Jan. 1. Didn't work. Just tried to do it to Feb. 1. No dice. Message reads, "Restoration Incomplete. Your computer cannot be restored to:"
What now? Can I back everything up while in safe mode?
Joeaksa 03-22-2010 09:11 PM
If you can get me the computer early tomorrow I can pull the HD and get a copy of it on a external drive.
Damm, wish this was yesterday because I am heading out of town tomorrow at 18:00!
Joe A
968rz 03-22-2010 09:11 PM
If you can see the external drive in Windows explorer while in safe mode you can push your data to it. If you can't, you can do as stomachmonkey suggested.
Rick Lee 03-22-2010 09:14 PM
I got the backup going and it's gonna take a lot of hours. But it's been a while since it's run this long without locking up, so I'm just letting it sit and back up. I might be ok here. I can live without the laptop, but I need what's on it.
spuggy 03-22-2010 11:30 PM
Do the fans run a lot? Could be overheating. If the fans are dead (or full of dust bunnies), that might explain something too. This freeware program Dell Inspiron Inspiron/Latitude/Precision fan control will show you all the temperature sensors and let you control/force the fan settings. Works for most Dells.
Is the memory flaky? Try seeing how long MemTest86+ will run for. Swap in good memory, or test your memory in a machine that doesn't crash.
Universal Boot CD is full of motherboard/disk testing programs. Free, bootable.
Almost never a hard drive, unless you can hear it either constantly ticking or recalibrating (slow recal to track 0, followed by a fast seek back to the sector it was trying to read).
If it has data you want, I'd yank the hard drive and back it up in a machine that's usable first. Stick a scratch 10 or 20Gb drive in for testing purposes.
Joeaksa 03-23-2010 04:31 AM
I hear that all the time! Dammit, back up your data more often!
I do it at least twice a week. Just keep a USB drive handy and copy it there, or network it with your desktop and transfer it across.
If you want to strip the drive and do it right will be back in a couple of days.
Rick Lee 03-23-2010 06:38 AM
I don't even recall if my fans have run in the last few months. My wife always uses this one on the couch and rarely on a hard, flat surface. It's often almost too hot to touch on the bottom. I figure its hardware is largely on its last legs and I don't mind buying a newer shell on eBay and throwing in this hard drive. My external hard drive has been backing everything up for the last eight hours or so. Should be done in another few hours.
red-beard 03-23-2010 07:08 AM
PM me your mailing address. I have one which should work.
slodave 03-23-2010 12:15 PM
From this, it sounds s if you have an overheating issue. Get a can-o-air and blow it through the exhaust vent. Take it outside :).
The symptoms you describe fit an overheating laptop.
Rick Lee 03-23-2010 12:38 PM
Thanks. But isn't the damage already done?
Joeaksa 03-23-2010 01:36 PM
Possibly yes, possibly no.
Usually when it really overheats it shuts down within a few seconds.
Best is to get your data off of it and then go from there. I would wipe the drive clean, put a new copy of the OS and your programs on it and see how it does.
Rick Lee 03-23-2010 04:09 PM
Ok, I just pulled the keyboard off and hosed the whole thing down with can of air, got the fan real good and clean. Froze up on me again after about 10 min. and didn't feel warm at all.
island911 03-23-2010 05:46 PM
You could pull the HD and just boot to the BIOS ...bring up the BIOS screen and see if it locks on that.
or Boot to install CD ... just to isolate the problem (cmptr or HD)
If the problem is flakey hardware, you could try to find the same model notebook on Craigslist, and swap your drive into that.
island911 03-23-2010 05:52 PM
I just check CL for a Dell Latitude D610 ... that's pretty much a base model to the Dell Precision M60 ...which I have sitting on a shelf. Let me know if you need to borrow it ...or install CD's ...
Rick Lee 03-23-2010 05:54 PM
Island, could I just install my hard drive in there and see how it works to tell whether my issue is hardware or software?
slodave 03-23-2010 05:57 PM
At this point it may not be a heat issue anymore, but, do the fan(s) spin? Also the heat sink has radiator fins and sometimes after prolonged use, the fins become blocked. That's why I suggested blowing the air in at the exhaust port.
Just an FYI, most of the time, heat will not affect the laptop/desktop - other than making it shut off randomly. Processors are really tough and can stand up to the heat for quite a while.
I would suggest, like others, that you take the HD out, hook it up to another pc and get any data you want off of it...
Dave
Hugh R 03-23-2010 07:28 PM
Dave,
while we are on the subject, the Dell desktop that I called you about over the weekend, I defragged it, got rid of everything that I could in terms of add on games, and did what ever compressing and such that I could find on system maintenance. When my BIL connects to ATT internet it runs really, really slow to load pages, any tips? He's using Firefox. He knows NOTHING about computers, and me, not a whole lot more. Should I use RegCure, or doublemyspeed.com or one of them?
island911 03-23-2010 08:34 PM
Rick, that's what I was thinking. email me ...
you could also just get one of the USB hard drive enclosures for ~$20
...put your HD in there, and plug it into a working computer.
LeeH 03-23-2010 08:51 PM
Hey Rick - I've got a Latitude 600 if you need to check out your HD. Mines been a bit flaky lately, too. Funny (well not really) but it only seems to have problems when I'm streaming something from Netflix.
Rick Lee 03-28-2010 08:18 PM
UPDATE
Got a new 160GB hard drive and hard drive enclosure today. Installed new HD, loaded Windows from an OS disk, copied some files over from my old one via the enclosure and....after about 20 min. online it locked up again. WTF is causing this? How can it still be happening with a new HD and reloaded Windows? Also, I can't get the new AVG free version to load either. Really getting frustrated with all this.
porsche4life 03-28-2010 08:20 PM
That sounds like a virus... You've been looking at too much porn boy....
