Can not find coolant leak...any ideas?
My wife has a 2003 Jeep Liberty with a 3.7 V6. I have needed to add a quart or more of coolant every week for the past month. I can't find the leak.
- I have had the system pressured checked by a shop. It held pressure okay.
- No drips on the ground.
- I have looked all over the engine while it was running at operating temp and no signs of a leak.
- Hoses are in good shape.
- No water in the oil.
- Check the heater core, no leaks.
- Tried a can of Bar Stop leak stop gunk - no luck.
Hoping it's not a head gasket. (I thought the pressure check would show something like this) Is there a way to check for that?
Does anyone have any suggestions what else to check?
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 04-12-2010, 09:51 AM
have you looked at the overflow tank or pressure tested the radiator cap. had a 850 wagon that had the same thing as you. turned out to be the overflow tank and radiator cap. the fluid was leaking while driving.
ken
87 targa
Old 04-12-2010, 10:02 AM
Evolved
Mo_Gearhead's Avatar
Remove the radiator cap ( do they have one - or just a over-flow bottle?)
Anyway - check it cold and hot, You are looking for excessive bubbling in the coolant. Culprit = Head gasket
But it could also be an intake-runner leak also. Any tell tale signs at exhaust pipe?
Remember - If it isn't leaking it - it's digesting it.
Edit: You could pull the spark plugs and look for 'washout' on a particular cylinder.
Don't fear the reaper.
Old 04-12-2010, 10:04 AM
Certified Pre-Owned
BGCarrera32's Avatar
Sounds like classic head gasket unfortunately.
My Mom had an Oldsmobile with that Quad 4 thingie and you'd drive along just ho-hum, all of the sudden coolant steam rolling out from under the hood everywhere, pull over pop the hood and then nothing. Coolant was leaking from the head gasket to the outside of the head, just dropping back a couple degrees in temp would seal it right up again...no coolant anywhere to be found. Weirdest failure mode ever and confirmed by the GM dealer.
'84 Carrera Coupe
Old 04-12-2010, 10:25 AM
Checked out
McLovin's Avatar
Sounds like a head gasket. Do as Mo Gearhead says, pull the plugs and you may confirm the answer right away. If coolant is getting into a combustion chamber, that spark plug will be much cleaner than the others.
Old 04-12-2010, 10:30 AM
TerryBPP's Avatar
Could be a bad EGR valve. Check for white smoke out of the tail pipe.
Old 04-12-2010, 10:50 AM
fastfredracing's Avatar
I am assuming that this a 3.7 Litre?? I have been doing quite a few head gaskets on these lately. A dye test will show if it is in fact leaking.
For the life of me, I cant figure out why they did away with the tried and true 4.0.
No left turn un stoned
Z-man's Avatar
How's your oil? Any milkshake looking substance in it?
If it isn't a head gasket, it could be a crack in the head - that only shows up if the engine is hot, so normal leakdown tests won't show it.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 04-12-2010, 12:07 PM
Oil is dark, no sign of water. I will pull the plugs and see if I can see any signs that water may be getting into the combustion chamber. Then see if I can get a pressure test while it hot.
PorschePilot
MID9 Member
Old 04-12-2010, 01:00 PM
Pressure tests can sometimes do more harm because often the tester puts more than the system is rated for to "find" the leak. This ends up popping the end tanks off the heater core and radiator in short time down the road. If its not a head gasket then you should get some dye and a blacklight on there.
Old 04-12-2010, 04:00 PM
Can someone please tell me more about the dye test? Is this something I can do at home?
PorschePilot
MID9 Member
Old 04-12-2010, 04:13 PM
There is a test that checks for the residue of hydrocarbons in the coolant. not really a dye test.
Does the exhaust have a sweet smell to it?
Turn on the heat and see if you smell coolant through the vents.
When you pressure test the system do it when the engine is dead cold.
Hope it's not your head gasket.
Good luck
-Adam
Old 04-12-2010, 05:30 PM
AutoBahned
RWebb's Avatar
it is a dye that fluoresces under UV light - dye = cheap; light = $
I fergit what they call it in the auto world... ask at a FLAPS or a good repair shop -- FLAPS might loan you the light/tool to check for the dye with...
Old 04-12-2010, 09:35 PM
