Zeke's Avatar
Need help with finding a v-belt pulley.
Totally confusing. McMaster Carr has hundreds. I don't need this to be difficult.
What I need is a fairly large diameter pulley with a 1/2" bore to reduce the speed of a bandsaw. I've checked eBay and I guess I don't know the nomenclature. And all of the belt profiles are really just too much.
What belts are typically used on power tools like a table saw? AX or something like that? I don't know what an AX is.
Someone please help me find a stupid pulley for not a stupid cost. Anything over 8" diameter will be OK. I can get the ratios I need from there by selecting my drive pulley diameter.
TIA!
PS, will buy used if you have such an animal.
Old 04-28-2010, 05:59 PM
Zeke's Avatar
Off the subject, but I thought there was a 15 minute delay before posts were recorded. This thread has gone almost an hour and no one has even looked?
Old 04-28-2010, 06:50 PM
lm6y's Avatar
How wide of a belt are you using?
Brent
Early85 944
LM6Y Paint Code
Old 04-28-2010, 07:04 PM
lm6y's Avatar
Try this part number at McMaster Carr : 6245K55
McMaster-Carr
Just a quick search, I hope it helps!
Brent
Early85 944
LM6Y Paint Code
Old 04-28-2010, 07:08 PM
A930Rocket's Avatar
No idea on the pulley, but can you use an electronic speed control? Something like a rheostat from HD to control the speed infintely?
Old 04-28-2010, 07:09 PM
VincentVega's Avatar
This one might work, McMaster-Carr
If the link doesnt work, Part Number: 6245K941
Old 04-28-2010, 08:16 PM
Wouldn't you need two pulleys?
Electric motors make equal torque from 1RPM to max RPM so you could just slow the motor down electronically without loss of torque.
Old 04-28-2010, 10:33 PM
Zeke's Avatar
Yep, those will work. AFA electronic control, I think that will cost more than a pulley. Also, I read sometime ago that induction motors don't like that kind of control. I'm pretty sure my motor is an induction type. I don't see a capacitor start either.
Old 04-29-2010, 08:52 AM
