Tomato growing question
I am growing tomatoes from seeds, they are about 1 inch tall. Each container has 3-4 plants, at what point do you remove the weakest plants if in fact you do? And when should they be put in a larger permanent pot?
Thanks in advance
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Information Overloader
I usually wait until the tomatoes show up on the table at work with a sign saying "Help Yourself"...
i would put them in the ground (or pot) and let them grow a bit. then just clip the weaker looking plant.
poof! gone |
Since you typically only plant one per pot (or a couple of feet apart)...anytime you like...for both questions. If you have several together, you should probably wait until they are about 6 inches or so...and seperate them all into different containers. Most will survive. if you shade and water them well at first.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
