-   -   Prime Example of Fatigue Failure... (http://forums.pelicanparts.com/off-topic-discussions/542838-prime-example-fatigue-failure.html)
M.D. Holloway 05-18-2010 08:04 AM
and a leopard print one I wear when I'm feeling frisky!
masraum 05-18-2010 08:45 AM
Materials was one of the more interesting classes I remember from college, too bad I didn't finish it (I don't think)
sammyg2 05-18-2010 10:44 AM
Originally Posted by LubeMaster77 (Post 5355710)
Looks like E-3 to me :D
sammyg2 05-18-2010 10:49 AM
LOL many moons ago I was going back to college for about the gazillionth time. I had requested and recieved a copy of my transcripts and it said I took an introductory and advanced metallurgy class at Fullerton college in 1980 and got A's in both classes. Funny thing was, I don't remember taking either one of those classes. I don't remember drinking that much back then either ;)
Martin Glaeser 09-28-2011 07:54 PM
Opening graphic
This is a bit off topic but I have reccently written a maintenance learing module that covers among other things fatigue cracking. Would it be possible to have copyright permission to use the photo in the opening post please. Many thanks
Martin
NutmegCarrera 09-30-2011 10:28 AM
Looks to me like there was some inclusion in the base metal. Center of picture, and there appears to be a "path" leading to it from somewhere around the 5:00 position in the photo.
A crack can only propogate if there is a void. Usually they start on the outside, unless there was a flaw in the material such as this example has.
We had a very important shaft fail in my first job. Caused a paper machine roll to break under operation. Similar material. About 12" diameter. Under a LOT of tensile pre-load to counteract bending of the body of the roll. Long story short - lots of pieces of roll body material throughout the rest of the machine. Machine down for about 3 weeks to repair damage. Root cause of failure was a similar inclusion - however, ours was on the outside of the shaft.
M.D. Holloway 09-30-2011 10:47 AM
Martin
send me a PM and we can work sump'n out! ;)
Geary 09-30-2011 04:40 PM
Mike .. could you possibly tell us the dimensions, application, and an opinion of this shafts material? It just seems like quite a large keyway on a relatively small diameter shaft.
I have to wonder whether core strength was compromised in just the short keyway portion of the shaft during the heat treatment process, due to the irregular cross sectional shape. That's kinda what the photo looks like to me .. a large hard zone around the keyway, stealing uniformity from a core that's skewed off-center. Copper coating the keyway prior to heat treatment is a probable solution .. or replacing the key with splines. .. (just a layman rambling) ..
red-beard 09-30-2011 05:38 PM
In 1987, I saw guy wearing a pocket protector and thought it was pretty neat! Then I got better...
javadog 09-30-2011 05:44 PM
We ever going to learn all about this failure?
It's been 4 1/2 months and we're not going to get any smarter, so new guesses may not be forthcoming.
JR
livi 09-30-2011 10:56 PM
Thats an easy one, Lube.
You see its all to do with (doing my best Rowan Atkinson impression here) electro-magnetic orientation of the adjacent strata of atoms in relation to the inclination degree perpendicular to the direction of the force.
svandamme 09-30-2011 11:35 PM
In other words, it went tits up
livi 10-01-2011 12:05 AM
Well.. yes. :D
Por_sha911 10-01-2011 02:25 PM
http://forums.pelicanparts.com/off-topic-discussions/632411-interesting-street-sign.html
Martin Glaeser 10-02-2011 02:29 PM
Opening picture enquiry
You can email me at martin.glaeser@openpolytechnic.ac.nz
Cheers
svandamme 10-02-2011 09:45 PM
You must really love getting spammed to post your email adres in a public forum.
futuresoptions 10-02-2011 10:05 PM
I might not be the smartest man in the world, but I know what love is Jennay...
sammyg2 10-03-2011 10:31 AM
JR
Using a keyway like that to transmit torque is a big no-no under most circumstances.
An interference fit between the hub and the shaft would be optimum so the keyway would not see any shearing forces.
Also I'm guessing the keyway was cut with a standard end mill, leaving sharp edges. Stress riser city.
Design the hub with a taper lock or standard interference fit of .001" per inch of dia. up to 2", then additional .0005" per inch after.
If it's belt driven, make sure proper tension is maintained. Too loose can do that more than too tight, snapping a string like.
Have em cut the keyway in a way that eliminates the sharp edges.
If it's direct drive tell em to use a good laser alignment system to get the alignment just right to reduce vibration.
Don't have enough info to recommend a material upgrade.
Martin Glaeser 10-18-2011 02:43 PM
Photo request
Hi, any chance of a reply to the request to use the photo? We could probably buy a copy of your book.
Bob Kontak 10-18-2011 08:39 PM
Tits up in the ditch!
