-   -   Prime Example of Fatigue Failure... (http://forums.pelicanparts.com/off-topic-discussions/542838-prime-example-fatigue-failure.html)
M.D. Holloway 05-17-2010 10:28 AM
Another text book example of a type of failure - fatigue. I took this pic last week with my cell phone. A snapped shaft due to fatigue.
Fatigue is the progressive damage that occurs when a material is subjected to cyclic loading. The maximum stress applied is less than the stress limit of the material yet the material is subjected to a constant or random elongation, bending or compression which will eventually take its toll and produce a failure. Notice the twist patterns as well as the color differences on the below pic:
http://forums.pelicanparts.com/uploa...1274116838.jpg
Typically, a fractured piece will have a dark area which is an indication of slow crack growth, and a bright area which is an indication of sudden fracture. Fatigue begins with the crystalline structure experiencing dislocation. Eventually small micro-fissures develop which begin to compromise the physical integrity of the part, tool or material. Many materials will not normally recover if fatigue is relieved.
So, answer me this students-o-failure, why would the color be dark on the inside and not on the outside? How do you think the stress developed?
RAM 05-17-2010 10:48 AM
You have it back wards. The dark area is the area of sudden rupture while the brightly colored area is or slow crack growth. The crack initiation was at key-way and progresses inward as indicated by the "beach" marks. the dark area is of dimple rupture where the crossectional area was no longer large enough to handle the load and therefore the material Yield and UTS were exceeded.
javadog 05-17-2010 10:49 AM
I'm guessing that the color change ordinarily is a result of fretting and the color is from oxidized (very small) particles of the parent metal. Did this shaft stay together after the break?
The failure looks to have originated at the keyway. Was there a scratch or gouge in the bottom? I think I see one in the picture. I also see cracks starting to form at the corners. Was the key a bad fit in the slot?
JR
David 05-17-2010 10:55 AM
A dark area from slow crack growth could be from oxidation on the cracked surface along with the two opposite fracture surfaces fretting together and wearing away the beach marks, but that's not the case here.
I'd say the fatigue crack in this shaft grew pretty fast as evidenced by the relatively wide spacing on the beach marks by the key.
911Freak 05-17-2010 10:56 AM
I'm not an engineer (wish I was tho) and I didn't sleep at a Holiday Inn, so my ignorant guess (in euber layman's terminology) is the dark color is from heat as well as a collapse or degradation of the molecular structure of the metal (tearing it self apart and compacting on its self) as it fractures?
The brighter outer area is a faster fracture and experienced less compressed energy when fracturing?
pretty lame right?
Tishabet 05-17-2010 11:00 AM
Cool pic!
Here is one of my 944 axle after suffering a failure:
http://forums.pelicanparts.com/uploa...1274119121.jpg
JeremyD 05-17-2010 11:03 AM
Looks like a cat - and why is it smiling at me?
peppy 05-17-2010 11:32 AM
I thought it was a breast implant that had been USED too much.
I have been in OT for way too long.
island911 05-17-2010 11:33 AM
You can't assume that the material was isotropic when made. (cold-drawn?) And, strain-hardening (outer perimeter) can come from heavy flexing.
So, in engineering terms; Like a Ho-Ho ... hard chocolate outside, and a creamy/cakey filling inside.
Burnin' oil 05-17-2010 11:46 AM
I understand.
wdfifteen 05-17-2010 02:38 PM
The highest stresses on a shaft in torsion are at the surface, and the crack would start there if there was no keyway. Except, there is a keyway and it has sharp edges where it was machined into the shaft. The the sharp edges of the root of the keyway caused localized stresses high enough to cause a fatigue crack to initiate. If it had grown slowly the first part of the crack would have darkened by oxidation, but this one grew fast enough for the fretting (rubbing of the sides of the broken crack together) to keep it polished. The dark area on the inside of the shaft is where the remaining material was stressed beyond the point of ultimate failure and came apart. It appears dark because it is a rough surface. This might have been avoided if the corners in the root of the keyway had been radiused.
island911 05-17-2010 03:01 PM
That's not a torsion failure. . . more like reverse-bending fatigue. That 944 shaft, OTOH...
oh, and keep in mind that the key (in the keyway) likely provided support. ..it's not always so simple to point to corners as stress-risers. YMMV
sammyg2 05-17-2010 03:35 PM
LOL, I have three pieces just like that on top of my file cabinets in my office.
With just looking at the picture I don't see a stress riser or significant material flaw other than the keyway.
My guess is it endured too much radial load from misalignment causing it to bend at ever revolution which work hardened it until it became too brittle and sheared. Have you run any hardness tests on it yet?
Jeff Higgins 05-17-2010 05:50 PM
We need to know more about the material. Was it heat treated, and if so, was it a through-hardening steel or was it only surface hardened? It has discoloration of a pretty uniform depth around the diameter, which appears to follow the contour of the keyway as well, indicating it may only be surface hardened.
The keyway itself does not appear to be an issue. The bottom corners are well radiused for the size of the keyway. I only see one little crack propagating from the keyway, from the left side, and it appears as though it way have been a result, not the cause, of the failure.
sammyg2 05-17-2010 06:10 PM
My guess based only on appearance is is 4140 centerless ground shaft quality. Surface treated only.
M.D. Holloway 05-17-2010 08:45 PM
hint...
http://forums.pelicanparts.com/uploa...1274154344.jpg
M.D. Holloway 05-17-2010 08:58 PM
The dark portion of the fatigue fracture surface exhibits classic “beach marks”, “thumbnail marks”, “stop marks” and are clearly present in the darker portion of the fracture surface, the light portion of the fracture surface is where "fast fracture" (final separation) occurred. A common rule is Bright = Brittle fracture. Dark = Fatigue fracture.
porsche4life 05-17-2010 09:01 PM
Mike... Don't take this the wrong way but.... You wear a Pocket Protector don't you?
dhoward 05-18-2010 07:19 AM
He keeps his pocket protector in a pocket protector.
herr_oberst 05-18-2010 07:24 AM
He has a good pocket protector he wears to church.
