Transformed some junk into tack driver.....
I just built this rifle from pieces lying around the garage.
Remington 788 action with Atkinson stainless barrel chambered in 7mm 08 Canjar Precision trigger from inventory prior to Canjars death. Chet Brown 40 X stock with custom inlet made in the 80s. It appears to be carbon fiber over a foam core with full length aluminum bedding. Pachmayr recoil pad installed. Weaver T16 old style scope from the 80s UAG tactical bipod with Freeland rail adapter Receiver and stock are coated with three coats of Dura-Coat Tractical Black. http://forums.pelicanparts.com/uploa...1277661239.jpg http://forums.pelicanparts.com/uploa...1277661256.jpg http://forums.pelicanparts.com/uploa...1277661266.jpg http://forums.pelicanparts.com/uploa...1277661283.jpg http://forums.pelicanparts.com/uploa...1277661294.jpg Are you starting to see a patern? I built this one 3 mounths ago. http://forums.pelicanparts.com/uploa...1277661515.jpg |
i've heard that your engines are really good too.
nice work henry. |
reminds of the scene from the Good, the Bad and the Ugly went Clint builds a revolver from 4 different weapons. Very nice work sir.
It seems that building a quality firearm is very similar to building a high performance engine. 1) You pick an interesting formula 2) Pay close attention to tolerances 3) finish with aesthetically pleasing or task appropriate touches. 4) Then make some smoke and see what happens. I guess the term "killer" can apply in both cases. |
i like it!!
| All times are GMT -8. The time now is 09:58 AM. |
