Now in 993 land ...
Speeder,
This makes no sense. If you have 120 PSI in your tank and a good size hose going to your 600 ft/lb impact, with a directly installed impact socket, it should work just as well as your shop buddy's. I haven't had a bolt I couldn't get lose with my IR and home set up. Plenty of rusty balancer bolts in my past ... George |
Team California
I'm pretty sure that my 1/2" IR gun is not 600 ft./lbs. I'll take a look at it tomorrow but it's not quite that good. As for my tank, I run a lot less than 120 psi. I'll take a look at that as well, not sure what my max pressure is. Although compressed air is certainly not complicated, I don't have expert knowledge of the equipment. Mine is strictly small-fry, I'll photograph my compressor and gun and then post it here to hopefully learn something. Thanks...
Denis |
Senior Member
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
That makes it a sure thing that the owner deserves to have it fixed correctly!
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
. Tank capacity matters for continuious use (blasting, grinders, painting, etc.), not for impact wrenches and the like.
