126coupe's Avatar
Help me out with Mac Book/wireless printer install
With my Mac book the installation went perfectly, but trying to install the software for the printer with my daughters mac book if not working out.
The disk reads fine, but I get a message "The HP installer has detected at least one open application. Please quit all HP applications before continuing.
Thanks in advance
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 08-03-2010, 01:56 PM
Moses's Avatar
Don't need to install CD printer drivers at all. In fact, uninstall it.
If it won't work with your wireless printer, download a Gunenprint driver at sourceforge.net It's free.
Old 08-03-2010, 02:15 PM
126coupe's Avatar
I had to install the CD for my mac to recognize the new printer, why would my daughters mac be any different????
28' Pace Trailer
Old 08-03-2010, 02:20 PM
The Unsettler
stomachmonkey's Avatar
Moses is correct.
Highly unlikely that you need to install from disc.
Driver should already be there unless you reinstalled the machine at some point and customized the driver package.
FYI, you've got a process running in the background.
Go to SysPrefs/Accounts and look for a Log In item that is HP related. Turn it off.
Or run Activity Monitor and look for the suspicious process and terminate it.
If you want to go the geek route fire up Terminal, type TOP, look for offending process and it's associated process identification number and type kill PID ###
"I want my two dollars"
"Brandon Won"
Old 08-03-2010, 02:21 PM
The Unsettler
Run Printer Utility, SystemPrefs/Printers and Fax, to install/add printers.
If the driver is not already present then use the HP CD.
If you really just want to use the HP CD you can always reboot and hold shift key to disable any autoloading background processes.
"Brandon Won"
Old 08-03-2010, 02:24 PM
126coupe's Avatar
Fixed it, I just had to restart the Mac
28' Pace Trailer
Old 08-03-2010, 02:26 PM
