-   -   Hmmm, what would this slip into? (http://forums.pelicanparts.com/off-topic-discussions/557068-hmmm-what-would-slip-into.html)
pwd72s 08-04-2010 07:28 PM
Maybe a 928???
Ford Racing Performance Parts - [Part Details]
masraum 08-04-2010 07:50 PM
Blah!
If you're going that route, you may as well get something good.
GM Performance 19211710 GM Performance Parts 427 LS7 Engine
GM Performance, using valuable data gleaned from the factory-sponsored Corvette C5R racing program, developed the LS7 with many competition-derived components and design features. It takes production small block performance to an unprecedented level while demonstrating the continuing adaptability of the engine's compact cam-in-block design. It is, quite simply, the largest, most powerful production small block V8 GM has ever produced. Each engine assembled by hand by a single specially-trained builder.
Specifications
# 505 horsepower @ 6200 RPM
# 475 ft/lbs of torque @ 4800 RPM
# 7000 RPM redline
# 11:1 compression ratio
# Unique engine block with larger 4.125" bores and pressed-in cylinder liners
# Forged steel crankshaft with 4.000" stroke
# Titanium connecting rods
# Cast aluminum flat top pistons
# CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
# Dry sump oiling system (does not include lines or tank)
# Camshaft with .591" lift
# Hydroformed exhaust headers with unique quad flow collector flanges
# Intake manifold with injectors (injector wiring harness)
# Fuel rails
# Throttle body
# Exhaust manifolds
# Flywheel and clutch
# Harmonic damper
# Water pump and pulley
# Coil packs, spark plugs, and wires
# Engine sensors
# Engine processor, air filter/air box, and accessory drive NOT included
A930Rocket 08-04-2010 08:00 PM
11:1 compression ratio?
What octane gas does it use?
Aurel 08-04-2010 08:08 PM
Could fit in a lawnmower:
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/u5M_BpcC67o&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/u5M_BpcC67o&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
pwd72s 08-04-2010 08:10 PM
Lessee...$14,500 for the Government Motors engine vs. $7 K for the Ford? Apples & oranges, money wise...
But if you believe there is no replacement for displacement backed by cubic dollars, I'll take that 550 horse chevvy and raise you...
http://www.fordracingparts.com/crateengine/main.asp
Schumi 08-04-2010 08:44 PM
11:1 is not high.
A new 987S has a 12.5:1 compression ratio.
RWebb 08-04-2010 08:52 PM
how about a Go Kart?
or the next closest thing... a 914
pwd72s 08-04-2010 08:53 PM
Yep, computer management systems allow for some pretty high compression ratios these days...even for use with pump gas.
Tobra 08-04-2010 09:16 PM
this, maybe a miata or 240-280 Z
pwd72s 08-04-2010 09:22 PM
How 'bout?
http://forums.pelicanparts.com/uploa...1280982137.jpg
Arizona_928 08-04-2010 09:56 PM
Image what you could do to the 5.0L with the 8k difference to the 427. Anyways It's all aluminum, and twin cams... Goodies would definitely be cheaper then to the 928 5.0L
Jim Richards 08-05-2010 03:07 AM
http://farm1.static.flickr.com/86/21...d58c8c79de.jpg
wdfifteen 08-05-2010 03:18 AM
Is it just me, or is doing donuts the biggest waste of time/fuel/tires since the Chevy Vega?
sammyg2 08-05-2010 06:35 AM
Ford Racing Performance Parts - [Crate Engines]
If all you want to do is convert gasoline into noise you could just install a harley engine. ;)
BTW, forced induction beats displacement every time.
GH85Carrera 08-05-2010 06:40 AM
Cubic dollars win it all. Look at the F-1 engine.
