laptop/netbook question
Friend gave me a netbook.
I want to drive a second larger monitor along with the little one on board. How should I do this? Thanks My netbook has a port that the printer cable plugs into. KT |
Doesn't have any sort of video out?
Printer out ain't gunna cut it.. You can try though.. Please video your attempt. :)
Sorry, I meant monitor/VGA cable plugs into.
It flashed the Microsoft screen on the second monitor at startup and then went to the netbook's screen after boot. KT |
What OS?
On my dells there is a blue CRT/LCD print on one key... You hit the blue Fn key and hit the CRT/LCD and it cycles the different video options... |
XP, I think?
It'll be my streaming video viewer/blogger trackside at this weekend's race. I want a bigger screen that passers by can see. :) KT |
Make/model?
Acer/ Aspire One
KT |
Assuming it is XP...
Right click on the desktop--->properties--->settings---> select output When the monitor is plugged in XP should recognize it... |
Thanks, I'll give that a shot in the morning.
Thanks again, gents! KT |
I have it set where the second monitor becomes an extended desktop of the netbook.
I can open second windows there. I can put the in-car footage on the big screen and chat with you jokers on the netbook!! ;) KT |
I own the same Netbook - It is far easier than that.
Hold down the "Fn" key and press the "F5" key three times, and you will be monitor only. I do this everyday. Before unplugging the cable, do the above again, except 4 times. You will see that there are other options (Both on, etc) as you are cycling through the different configurations. |
Nice!
Thanks! KT |
OK...
I tried the fn-f5 and now the machine won't find the second monitor anymore?!? KT |
I figured it all out.
After a restart I got it back. This is good. KT |
| All times are GMT -8. The time now is 02:25 PM. |
