-   -   Does Pelican freeze up all the time or is it my browser/connection? (http://forums.pelicanparts.com/off-topic-discussions/558721-does-pelican-freeze-up-all-time-my-browser-connection.html)
syncroid 08-20-2010 04:47 PM
I give up, I'm going for red wine
Oh....That sounds good. :) Me too.
JJ 911SC 08-20-2010 05:44 PM
May I sujest...
http://forums.pelicanparts.com/uploa...1282351120.jpg
Chalk Hill Estate | Wines
http://forums.pelicanparts.com/uploa...1282351426.jpg
stomachmonkey 08-20-2010 07:25 PM
I get the hang every 5-6th refresh/page change/post action.
Same thing at work and at home.
stomachmonkey 08-20-2010 08:26 PM
just hung for 40+ seconds. Pelican trying to connect to csvta.target.com
slodave 08-20-2010 08:28 PM
It's hanging again for me too.
JJ 911SC 08-21-2010 05:10 AM
Look likes...
Originally Posted by Wayne at Pelican Parts (Post 5517711)
I changed the ads at the bottom of the screen to only be Google text ads. I think that maybe it's hanging due to all of the ads trying to pull stuff from servers that it can't reach easily?
-Wayne
... Red wine helped.
No delay in anything in anything this morning except for me to get in gear. Damn booze :D;):D
stomachmonkey 08-21-2010 05:44 AM
-Wayne
Thanks, FWIW if the ad revenue helps offset your out of pocket cost I'm willing to deal with some slowness.
GH85Carrera 08-21-2010 11:39 AM
Wayne, Google does an amazing job of indexing the pages. On a few occasions I have googled a "fact" posted on the forum as a fact check. Many time this forum is at the top of the list. The very thing I was going to fact check is the top item. It made me laugh.
Jim Richards 08-22-2010 10:49 AM
It's still hanging up. I just had a couple of WSOD's, too. All on the 911 Tech Forum page.
pete3799 08-22-2010 11:07 AM
Hanging up here too.
Jim Richards 08-22-2010 11:09 AM
and again. WSOD. :(
Zeke 08-22-2010 11:12 AM
Very slow today.
Wayne, I wouldn't let this frustrate you in the least. I'm almost sorry I started the thread. We all appreciate Pelican Forums.
Jim Richards 08-22-2010 11:26 AM
yep. :)
Geronimo '74 08-22-2010 12:24 PM
Originally Posted by milt (Post 5519711)
Very slow today.
+1 on the slowness, today was not a good day.
+1 on the not letting it frustrate
JJ 911SC 08-23-2010 10:58 AM
Another curve ball, this will probably not help...
Wayne
Noticing that it's slow at time since I got to work. I decided to check it via my Iphone4...
You guess it, the Iphone seem to be faster or you would not be reading this :D:confused::D
The Iphone is on Rogers 3G System in Canada.
Tonight, I'll compare the Iphone to my home computer on Rogers Internet and we'll see.
J.J.
Halm 08-23-2010 11:07 AM
The slowness has returned to me as well. As a matter of fact approximately 15 minutes ago the website simply would not come up. And I tried twice, once on IE and once on FireFox.
Joeaksa 08-23-2010 11:56 AM
Same here with FF. Tried to open a page and it took over 2 minutes to do anything, then popped up just fine.
JJ 911SC 08-24-2010 05:05 AM
As seem on the other Thread
Slower at work???
Just ran the test page at work; over a second...
We are on Fiber going to Ethernet.
I'll run the connection test Speedtest.net - The Global Broadband Speed Test tonight a home to see the difference
http://forums.pelicanparts.com/uploa...1282651402.jpg
Put your shade on...
Also, I can use some additional help to see if we can track down this problem. If you are having difficulty get the forums to load, perhaps you can go to this link:
http://forums.pelicanparts.com/test.htm
and see if you can load the page. It's forums . pelicanparts . com / test . htm
If you can load that page fine, then the database may be having difficulty (that's a static page that doesn't use the database).
Also, if you can perform a tracert from your home computer and paste the results here, then that would be useful too. Keep in mind that the last hop on the tracert will not be functional, as my firewall will terminate there. If you don't know how to do a tracert, it's really easy. Go Start -> Run then type command.com. Then type: tracert forums.pelicanparts.com and it will start analyzing the path that your computer takes to reach the forums. Hopefully, it may emerge that one of the big pathways across the country is either clogged or misrouted. Again, here on COX I haven't seen any issues.
Thanks,
-Wayne
Load in .3147893245643 of a seconds (land base Internet)... of course my BBQ timer has not been calibrated for a while so others result may be different
Who Will Live... Will See
Das Babe
Das Babe Metalberiech
slodave 09-03-2010 12:01 AM
So far so good. I've not been on the laptop much today though. The iPhone has been pretty quick.
JJ 911SC 09-03-2010 02:01 AM
Déjà vu...
... Mes forums semblent beaucoup plus rapide ce matin :D:eek::D
