beancounter
jwasbury's Avatar
tire losing air, but I can't find a leak
I'm having a strange issue with one of the tires on my '06 Mini. It has a leak, usually slow, but other times not so slow. Most of the time it can go a week or so...pump it up to 30psi and a week later its at 20psi. Sometimes, like this morning, I'll find it completely flat, when I only just filled it a day ago.
I yanked the tire, filled up with air, then submerged it in my bathtub. Can't see any signs of a leak. I also made up a soapy water solution and sponged the entire wheel with it and found no leaks. The tire picked up a nail once and its been plugged, which is naturally the first spot I checked, but it doesn't seem to be leaking there. I guess I'll replace the tire, but I just can't understand with these symptoms why I can't locate a leak.
Anyone ever experience something similar?
Old 08-31-2010, 02:54 AM
Crusty Conservative
silverc4s's Avatar
I had a similar situation on one of four new tires mounted on 15" Fuchs for me by Discount Tire. I took the offending tire/wheel back to them & they deflated it & remounted to the wheel & rebalanced, etc.
Problem solved.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 08-31-2010, 06:15 AM
Registered Abuser
MT930's Avatar
Check the inside rim for dings.
I had one that lost air only when the car was driven, yanked the wheel and found the ding that was affecting the seal. I was really scratching my head until I pulled the wheel.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 08-31-2010, 09:12 AM
Friend of Warren
I had a similar situation, only mine was a constant loss of about 5lbs per day. Turns out I had a crack in the combination valve stem/tire pressure sensor. Tire shop found it and showed it to me.
Kurt V
Old 08-31-2010, 09:17 AM
Valve stem or bead leak....
Old 08-31-2010, 09:29 AM
Banned
Prolly a bead leak. You might have to put like 60 or more punds in it to actually find it.
Old 08-31-2010, 11:01 AM
crb07's Avatar
If it is a rubber valve stem push/bend it, you may here it start leaking.
Chris
89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute
Old 09-01-2010, 09:18 AM
abit off center
cgarr's Avatar
Had that happen and it only leaked when drive at speed, the stem would bend, then leak. Stop it was fine.
______________________
Craig
G2Performance
Old 09-01-2010, 09:39 AM
Double Trouble
targa911S's Avatar
The salt on the roads here pitted the bead rim on my wifes PT cruisers aluminum wheels.. Had to take the tires off and sand them smooth again to fix the problem. BIG PITA!
Old 09-01-2010, 10:11 AM
carreraken's Avatar
Had bead leak on my 'yota resulting from a poorly chromed wheel - the chrome was deteriorating along the bead... had to use bead sealer to stop the leak...
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 09-01-2010, 10:55 AM
GDNF2ET's Avatar
I had a similar issue with a 4runner I had..It would loose 15 - 20 pds in 2 weeks..Had the tire off and checked a couple times by different shops, till one day a shop figured it out..There way a very small leak within the rim..When the aluminum rim was forged, it musta had a pit or flaw in the metal..Small bubbles could be seen when submerged in water at the middle of the rim....
Old 09-01-2010, 12:24 PM
Burn the fire.
Brando's Avatar
valve stem or bead leak....
+1
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-01-2010, 01:18 PM
Make Bruins Great Again
Por_sha911's Avatar
Bead leak. Maybe it leaks more when the wheel is in a certain position. Either that or a neighbor is have fun with you by letting air out at night?
Joe
Old 09-01-2010, 03:26 PM
sometimes its the valve itself if its not screwed on tight or you just got a bad one or one that is sticking when you put air in it. but i suspect you've checked that first.
ken
87 targa
Old 09-02-2010, 05:47 AM
Pre Registered
tchanson's Avatar
Agreed. If you haven't done so, the first thing to do would be to make sure the stem is tight using an adjustment tool.
Tim
Old 09-02-2010, 08:44 AM
