Banned
trans fluid milkshake
my 740 volvo auto just did a odd trick
the rad coolant leaked into the trans fluid creating a milkshake oil is fine just the trans fluid and coolant are mixed flushing the coolant is eazy and I have a 240 auto rad to swap in [looks the same as the 740] but how to get the milkshake cleaned out of the trans ?? or is the trans toast and needs a swap ?? I have seen lots of oil+coolant mixed milkshakes from bad head gaskets but this is my first time for a trans fluid milkshake any ideas ???????? |
Unregistered
contamination from dihydromonoxide.
Not much you can do except drop the tranny pan (if a volvo even has one) and change the filter and then flush it several times. |
Targa, Panamera Turbo
Bad deal - below is a pic of a piston from a John Deer 4455 tractor. The engine developed a micro crack and a small amount of coolant made its way to the oil galley. Once there it set up a nice reaction to seize the piston and allow for pre-detonation to occur. The result....BANG! and about $12 large to fix and a nice 'hand grenade' part I use for training.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Thread Tools | |
Rate This Thread | |
