Motorcycle muffler mods to reduce noise
Hi all,
I've been stuffing about for a while building up a Japanese style custom bike, based on an old Honda CB400F. The muffler was rusted out when I got the bike so I replaced it with a cheapo ebay unit. I think it looks OK but it is REALLY loud. As you can see from the pics, it has a perforated tube which bolts in to the position I've shown in the third pic. Assuming I'm not Tim Hancock and only have mere mortal fabbing skills (at best), what would you suggest to bring the noise level down a bit. ![]() ![]() ![]() ![]()
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Control Group
that is a pretty cool scoot, how about some baffles, maybe with some fiberglass packed in there.
She was the kindest person I ever met |
Throw the whole system away and start over. That header design is among the worst I have ever seen and the "muffler" needs a float test in a pond. It's hard to believe it will even run, looking at that baffle design.
The nifty thing about motorcycles is that it's not all that hard to graft a part from Bike A to Bike B, if you do a little homework. You might even find a new system, or a good used one, for that model of bike. Early Honda fours have a fairly decent following. JR |
MAGA
Without knowing exactly what the internal structure is, my first thought would be to shove a washer shaped piece of steel or varying lengths of solid steel round stock maybe 2/3 of the way into the perforated tube and see how it sounds. You could use some wire to temporarily hold it in place. If that worked, you could permanently weld it in place.
My guess is that the exhaust dumps into the larger outer section of the muffler, then is forced through the perforated tube and then exits through the short narrow tip. Reducing the area by blocking perforated holes that the gas must pass through should IMO quiet the sound. In my opinion, it will be an exercise in trial and error as far as performance goes. At this point, I assume you are not too worried about eeking the last ounce of performance from the bike and simply want to quiet it down a bit. (I am in the same situation with my nearly completed cafe project.) It seems exhaust system design is somewhat of a black art and often involves trade-offs relating to where in the powerband the exhaust works best.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Sultan of Sawzall
My suggestion for quick/easy/affordable: Supertrapp
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Hey! I posted that last night but it is gone!!?? Hahahaaa. I wasn't even drinking!
Danny Ocean suggested steel wool. OP said he tried it and if tight it choked out the engine and if loose it did nothing. I agree with Java and Roux, start over. With salvaged parts you could get out less than 200, even if you bought a brand new supertrapp.
A nose heavy airplane flies poorly, a tail heavy plane flies once. Last edited by crustychief; 09-01-2010 at 10:48 AM.. |
"My guess is that the exhaust dumps into the larger outer section of the muffler, then is forced through the perforated tube and then exits through the short narrow tip. Reducing the area by blocking perforated holes that the gas must pass through should IMO quiet the sound."
That's right Tim, the muffler is otherwise empty aside from the perf tube. However, I can't wrap the tube as it pushes in, with a light interfence fit, from the muffler outlet. I'll try blocking a bunch of the holes with an internal sleeve. I thought of Supertrapps but they seem hard to come by here (Australia).
Unregistered
Wrap course steel wool or muffler fiberglass packing around that perforated sleeve and it'll quiet it down a lot. Or spend a bunch of money like others suggest. Up to you
![]() It's good that you are trying to quiet it down. You know what they call guys with loud obnoxious bikes nowadays, right? They even changed the definition in the dictionary. I saw it on TV! Last edited by sammyg2; 09-01-2010 at 09:14 PM.. |
Lets see more pic's of the bike
Banned
put a turbo on it
